about Find/Replace command in macro
    Mar 25, 2005#1
    macro 1:
    Find "[CaptorGroup]"
    Replace "[Group]"
    macro 2:
    Replace "[Group]"
    Question: Macro 1 can be run and no problem , but Macro 2 will reports "replace wrong". Who can tell me why ? thanks.
    206
      Mar 25, 2005#2
      Good question.
      Ask at [email protected] - let us know.
      Software For Metalworking
      6,687587
        Mar 26, 2005#3
        That's easy to answer for me. The Replace command must follow immediately a Find command. Use this modified macro 2, which moves the cursor back to begin of search string, if found once:
        Key Ctrl+LEFT ARROW
        Key Ctrl+LEFT ARROW
        Key LEFT ARROW
        Replace "[Group]"
        Of course, better is this macro:
        "[Group]"
        The find command already selects the string, so it can be directly replaced by the new string in your case, where no regular expression is used.
          Mar 27, 2005#4
          Thanks Mofi. Your says the right, and I just got this answer by IDM service support. Also thanks for your idea, that's very good :lol:
