Macro to split a large file and save the new ones with their first word as a filename
    Jan 13, 2015#1
    Is there a way to make a macro that will automatically split a large file into smaller ones when it encounters a specific string (I have made this work) and then save all the new files to a specified fixed location, using as a filename the first word of each file, trimmed from whitespaces?
      Jan 13, 2015#2
      Of course, this can be done with an UltraEdit macro. Better would be an UltraEdit scripting solution as macros do not support variables, but variables are supported by scripts. Therefore coding a script would be here most likely easier than coding a macro.
      But your explanation is a little bit poor. It would be good to show us with a block what active file contains on execution of macro/script and what should be produced by the macro/script. It would be enough to post a block of about 20-30 lines enclosed in code tags (button above edit field) showing active file contents and 2-3 "code" blocks showing what the created files should contain and which names the files should have.
      non-serviam wrote:using as a filename the first word of each file, trimmed from whitespaces
      A word cannot contain spaces. So this statement is not clear for me at all.
        Jan 14, 2015#3
        Mofi wrote:A word cannot contain spaces. So this statement is not clear for me at all.
        You are right. I meant a title of two words maximum without the whitespace between them.
        The format of the original file is:
        Original.txt
        title1
        stuff1
        stuff1
        stuff1
        end word
        title2
        stuff2
        stuff2
        stuff2
        end word
        title3
        stuff3
        stuff3
        stuff3
        end word
        And I would like to get:
        title1.txt
        title1
        stuff1
        stuff1
        stuff1
        end word
        title2.txt
        title2
        stuff2
        stuff2
        stuff2
        end word
        title3.txt
        title3
        stuff3
        stuff3
        stuff3
        end word
          Jan 14, 2015#4
          Okay, here is the code for an UltraEdit macro working on your example data with UE v21.30.0.1016.
          PerlReOn
          Loop 0
          Find MatchCase Select "end word"
          IfSel
          Key HOME
          Key END
          NewFile
          Find RegExp "[a-z]\w*([ \t]+\w+)?"
          SelectLine
          Find MatchCase RegExp SelectText "[ \t]+"
          Replace All ""
          Key END
          DeleteLine
          SaveAs "^c.txt"
          SaveAs ""
          CloseFile NoSave
          Find MatchCase RegExp "^(?![\r\n])"
          And here is the same code again indented and with comments for storing as text backup of binary macro and better understanding.
          I suggest to use file extension uem and use the syntax highlighting wordfile for text version of UltraEdit macros.
          PerlReOn
          //  Find the keyphrase and select everything from current
          //  position of caret to end of searched and found string.
          //  Was anything found and is therefore something selected?
              IfSel
          //  Move caret to beginning of the line with the keyphrase.
                  Key HOME
                  IfColNumGt 1
                      Key HOME
          //  Copy the selection. There is hopefully still something selected.
          //  Then cancel selection and move caret to end of line with keyphrase.
                  Key END
          //  Create a new file, paste copied text, move caret to top and search
          //  for a word starting with a letter in any case and optionally a
          //  second word after 1 or more spaces/tabs.
                  NewFile
          //  Could one or two words be found in entire text?
          //  Copy those one or two words into a new line at top of new file.
          //  Select this line and run on this selection only a regular expression
          //  replace to remove all spaces and tabs if two words were found before.
                      SelectLine
                      Replace All ""
          //  Reselect the remaining sequence of letters, digits and underscores,
          //  copy them to clipboard, delete the inserted line and save the new
          //  file in current working directory with appropriate name.
                      Key END
                      DeleteLine
                      SaveAs "^c.txt"
          //  In case of not at least 1 word could be found starting with a letter,
          //  let the user of the macro enter the file name on saving new file. The
          //  macro user can also cancel saving this new file with strange content.
                      SaveAs ""
          //  Close the new file.
                  CloseFile NoSave
          //  Move caret on next none blank line in file to split.
          // Clear used user clipboard 9 and switch back to system clipboard.
