Find & save to file
Find & save to file
12
    Sep 08, 2005#1
    I need to find a specific string in one big text file and save it to a new file.
    Below are the sample of the text.
    1.0 abc
    1.5 def
    2.8 abd
    2.7 bfv
    2.9 bbg
    2.0 bbh
    2.2 ffg
    2.1 ddf
    3.4 jjj
    3.2 hhh
    3.9 lll
    4.5 kkk
    What I need to do;
    All strings that start with 1.XXX will be saved as 001.txt
    All strings that start with 2.XXX will be saved as 002.txt
    All strings that start with 3.XXX will be saved as 003.txt
    Pls advise on how to create the macro.
      Sep 09, 2005#2
      Below are my attempt on creating the Macro;
      UnixReOn
      Find RegExp "^[2]\.[0-9]*.*"
      NewFile
      SaveAs "002.txt"
      Problems are;
      1. I tried the RegExp via Find function and it works well, so I guess the codes are correct.
      2. I run the Macro only to find out that it just created the 002.txt with no text inside it. Should I use a Loop for it? I not sure how to do it actually.
      Pls help.
      Thank you so much.
        Sep 09, 2005#3
        Your example expanded (not tested):
        UnixReOn
        Find RegExp "^[2]\.[0-9]*.*$"
        CopyAppend
        NewFile
        SaveAs "002.txt"
        12
          Sep 10, 2005#4
          Thanks Mofi,
          I tried to run the Macro using the sample text given earlier but got error "Search string not found". No text file created also.
          UnixReOn
          CopyAppend
          NewFile
          SaveAs "c:\002.txt" <-- is this correct?
          Note that I have added the path in the SaveAs portion(in bold).
          Questions;
          How do I process for the rest of the content?
          Do I have to copy paste each code. Example below;
          UnixReOn
          CopyAppend
          NewFile
          SaveAs "c:\002.txt"
          Find RegExp "^[3]\.[0-9]*.*$"
          CopyAppend
          NewFile
          SaveAs "c:\003.txt"
          Find RegExp "^[4]\.[0-9]*.*$"
          CopyAppend
          NewFile
          SaveAs "c:\004.txt"
          Is there a much easier way? I notice there is a character ^c to for clipboard, can we use this?
          Pls advise.
            Sep 11, 2005#5
            The path specification in the SaveAs command is correct (only one '\').
            I now tested it and replaced the $ at end of the regular expression search by a \p to avoid that all found strings are stored in a single line. And I removed the square brackets around the first number, because they are simply not necessary.
            Activate also the macro property Continue if a Find with Replace not found for your macro.
            What you also have forgotten is the CloseFile command. After first search loop and SaveAs the next search loop was running at the already saved new file and so nothing was found.
            Last I also added with SelectAll and IfSel commands a detection, if the new file really contains anything. If not the new file is closed without saving it to avoid creation of files without content (0 byte file size).
            Here is the modified macro:
            UnixReOn
            Find RegExp "^
            1\.[0-9]*.*\p"
            CopyAppend
            NewFile
            SelectAll
            IfSel
            SaveAs "c:\00
            1.txt"
            CloseFile NoSave
            ... copy green block also for numbers 2 to 9 here ...
            Although ^c could be used for Find and SaveAs, this would unnecessarily complicate your macro for your example. Using ^c would need a modification of the source file to temporary remove all already found lines by using CutAppend instead of CopyAppend. Also it would be necessary to have a nested loop, which is not possible in UltraEdit's macro language, so the inner loop must be put in an extra macro. I know how to write this 2 macros, but it is not necessary to do that until the number at starting of each line before the point is not increasing.
            7
              Jan 05, 2008#6
              I tried the above and it only copied exactly the search string though into the file.. not the line on which it was found.
              What I am searching is a file that contains thousands of lines like the following:
              NUM: 9030
              SEV: 2
              TXT: TLSX is in error \E, correct and restart
              Plus a bunch of other additional lines in the file, not just these lines.
              I optimally want to turn this into a CSV file that looks like the following for each entry.
              9030,2,TLSX is in error \E, correct and restart
              The Macro I currently have is (which right now just copies "NUM:" into the file.
              UnixReOn
              Find MatchCase "NUM:"
              CopyAppend
              NewFile
              SelectAll
              IfSel
              SaveAs "C:\CRSTMP\UETmp.txt"
              CloseFile NoSave
              Christopher
                Jan 05, 2008#7
                Hi Christopher,
                you need to select the entire line(s) with a regular expression search or only the searched word is selected and copied. Here is the macro you will need to get the CSV file.
                The macro property Continue if a Find with Replace not found or Continue if search string not found must be checked for this macro.
                UnixReOn
                Bottom
                IfColNum 1
                Find MatchCase RegExp "^NUM:.*\pSEV:.*\pTXT:.*\p"
                CopyAppend
                NewFile
                Find MatchCase RegExp "^NUM:\s*(.*)\pSEV:\s*(.*)\pTXT:\s*"
                Replace All "\1,\2,"
                Add UnixReOff or PerlReOn (v12+ of UE) at the end of the macro if you do not use Unix style regular expressions by default - see search configuration. Macro command UnixReOn sets the regular expression option to Unix style.
                7
                  Jan 07, 2008#8
                  Sweet! Thanks that worked like a charm and did everything I needed it to!
                  Thanks a lot!
                  Christopher
