Column Align Macro
5
PostOct 04, 2005#1
Hi folks.
After searching this forum and not finding anwers, I'd thought I ask the experts before I write my own macro to do this.
What I would like is some way to vertically align, seperated with spaces, text elements and operators. So this:
variable = "Some kind of string"
var2 = 12800
var3 = var 4 = 0
after higlighting the lines and executing a macro would produce this:
var2     = 12800
var3     = var4                  = 0
Anybody have some macro code that does this? MultiEdit32 does this just great and I might end up converting that source into something that will work with UE, but it doesn't hurt to ask first.
206
PostOct 05, 2005#2
Look at Column > Convert to Fixed Column
Separator character set as =
Scan and Convert
5
PostOct 06, 2005#3
Close enough for jazz. I'll play around with it more.
Thank you.
344
PostOct 06, 2005#4
The problem is that these column actions have no macro-command.
I think you won't find a satisfying solution for this.
Anyway, mrainey's hint helps if having many columns to adjust.
In my example, a "=" sign was standing at each end of the line, I had to delete these manually by column-marking.
Any idea how to avoid those = at the end ?
example:
a = 1
intb = 123
a = 1=
intB = 123=
greets, Bego
5
PostOct 07, 2005#5
I've played around with this some. At first I thought I wasn't using it right. After experimenting with it for hours, the closest I can come is nearly what Bego writes. And no Bego, I didn't find a way to avoid the ='s at the end of the lines.
Maybe this weekend I'll work on writing a macro to do it properly.
It kind of surprises me that UltraEdit doesn't have this built in or macro that the user can install. Gotta start somewhere I guess. :)
206
PostOct 07, 2005#6
Something like this macro should help to clean up your file:
UnixReOn
Find RegExp " *=$"
Replace All ""
Find RegExp " *=$"
Replace All ""
344
PostOct 08, 2005#7
Hi guys,
Those workaround do well. Thanx.
But I think we found out (once more) that UE deserves a real macro-programming language with real variables etc. :(
Please force this in your improvement-suggestions to IDM.
rds Bego :D
11
PostOct 08, 2005#8
I played around a little too and came up with the macros listed below. they execute painfully slow IF you have a source-file with many functions in it and the function-list is on. UE isn't very quick at building this list.
Anyways, give it a try.
1. SDUE_Align: prompts for the alignment-chars to be used (can be a string, e.g. ":=" )
Clipboard 6
Clipboard 7
Clipboard 8
PlayMacro 1 "SDUE_SelBlkCompl"
Cut
PlayMacro 1 "SDUE_Pos1"
GetString "Alignment character(s)"
Key UP ARROW
Key HOME
IfColNumGt 1
Key HOME
Clipboard 8
Key END
PlayMacro 1 "SDUE_QuoteRegExp"
Key HOME
IfColNumGt 1
Key HOME
Clipboard 8
Key END
NewFile
Clipboard 8
Find RegExp "^p"
Replace All "^c^p"
Find RegExp "%*^c"
Replace All "^c"
Find RegExp "^c^p"
Replace All "^p"
SelectAll
Clipboard 7
Cut
Clipboard 8
Find RegExp "^c?++^p"
Replace All "^p"
Find RegExp "%^c^t"
Replace All "^c "
TrimTrailingSpaces
SelectAll
Clipboard 6
Cut
ColumnModeOn
Find "^p"
Replace All " ^p"
Key END
Clipboard 7
SelectAll
TrimTrailingSpaces
SelectAll
Clipboard 5
CloseFile NoSave
DeleteLine
Key UP ARROW
Key UP ARROW
Paste [code]
Sub-Macros called by the above:
SDUE_SelBlkCompl - completes a selection to cover full-lines
IfSel
Cut
Key UP ARROW
Key END
Key RIGHT ARROW
Find "^p"
Replace All SelectText "^c"
Key LEFT ARROW
Key END
Key RIGHT ARROW
SelectLine
SDUE_QuoteRegExp - quotes UE-style regexp-chars; required to align on characters like the asterisk.
IfSel
Cut
NewFile
Find RegExp "^([%$?*+^^^[^]]^)"
Replace All "^^^^^1"
SelectAll
CloseFile NoSave
SDUE_Pos1 - reliably position on column 1 regardless of setting for Home-key
Key HOME
IfColNumGt 1
Key HOME
PostOct 10, 2005#9
Hi DarkTurok
OK, I got it. You use the "trick" that pasting in column-mode creates trailing spaces, so the longest "leftside" string determins
the place where to put the "=" and the rest.
--> Thats enough for me :-)
Anyway, this solution still stays a bit limited.
Things like comments (lines without a "=" sign) do infuence the "="-position.
int MyBigLeftValue = 1;
//here we go with a fat comment
int myNotSoBigVaule = 2;
ends up like this:
Also, in the current version, you have to mark the following line too, or the last line will not work properly.
Reason: replace ^p wont work in last line; there is no ^p.
So replace the SDUE_Align code like this:
Clipboard 8
Replace All "^p"
Find RegExp "%^c^t"
Replace All "^c "
Bottom
Key BACKSPACE
TrimTrailingSpaces
SelectAll
if you do not like the promt dialog and you always want to align for e.g. "=",
replace:
with:
Thanx, Alex
11
PostOct 11, 2005#10
Thanks for the comments and the improvements.
I was aware of the "line without alignment-character" issue. It's no big deal for the purposes I use the macro most often for, that is aligning assignment blocks and variable declarations - you rarely find thes at the very end of a file anyways :)
