How to include in a macro
    Sep 28, 2004#1
    :cry:
    I would like to put a current line on top of a window; this can be done with the <Alt+Num"-"> key combination. But how can I include this combination in a macro?
    Basically I want to look for a word, and then put the line with this word on top of a page.
    Frank
    6,614548
      Sep 28, 2004#2
      This is simply not possible. The macro commands of UltraEdit are primary for editing purposes. Functions of UE, which are assigned to a key or key combination cannot be executed inside a macro, if there is no macro command available for it. If you look at the available macro commands, you will not find any special scrolling feature. Only simply cursor movements are available.
