LOOP to copy and append
74
Advanced UserAdvanced User
74
    Oct 14, 2004#1
    Situation after running my initial script this is my output. Problem is there are more then one "Figure" associated with the <item><?hotspot color="blue" href=__!'#-##' >
    What I need to do is copy the "<item..." information and append it to all the figures below it till it reaches the next "<item", then repeat.
    I know this would be a loop, but how
    Find regexp "<item><?hotspot color="blue" href=__!"
    select
    copy
    replace ">Figure.*"
    SAMPLE TEXT:
    <item><?hotspot color="blue" href=__!'2-17.1A'
    >Figure 2-85. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.1'
    >Figure 2-86. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.3'
    >Figure 2-87. test<?/hotspot></item>
    >Figure 2-90. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.4'
    >Figure 2-88. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-18'
    >Figure 2-89. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-18.1'
    <item><?hotspot color="blue" href=__!'2-18.2'
    >Figure 2-91. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-19'
    >Figure 2-92. test<?/hotspot></item>
    OUTPUT DESIRED:
    <item><?hotspot color="blue" href=__!'2-17.1A'>Figure 2-85. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.1'>Figure 2-86. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.3'>Figure 2-87. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.3'>Figure 2-90. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-17.4'>Figure 2-88. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-18'>Figure 2-89. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-18.1'>Figure 2-90. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-18.2'>Figure 2-91. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-19'>Figure 2-92. test<?/hotspot></item>
    <item><?hotspot color="blue" href=__!'2-19'>Figure 2-90. test<?/hotspot></item>
      Oct 15, 2004#2
      Try this macro, it works for your example:
      Find RegExp "<item><^?hotspot color="blue" href=__!*$"
      IfNotFound
      ExitMacro
      Cut
      Key DEL
      IfCharIs ">"
      Key HOME
      Key DOWN ARROW
      IfNotFound
      ExitMacro
      Cut
      Key DEL
      74
      74
        Oct 15, 2004#3
        Still have the problem of Figure #'s left without an item tag.
        Results were:
        :arrow: >Figure 2-90. test<?/hotspot></item>
        :arrow: >Figure 2-92. test<?/hotspot></item>
        Thank you for working on this with me. I'm still trying to figure this out. :lol: Max
          Oct 15, 2004#4
          this is kinda querky..I restarted my PC and ran the script again, the results were exactly what I wanted. But when I ran it on another test file nothing happened.
          Test File:
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-17'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-17.1A'
          >Figure 2-85. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-17.1'
          >Figure 2-86. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-17.3'
          >Figure 2-87. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-17.4'
          >Figure 2-88. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-18'
          >Figure 2-89. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-18.1'
          >Figure 2-90. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-18.2'
          >Figure 2-91. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-19'
          >Figure 2-92. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-19.1'
          >Figure 2-93. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-19.2'
          >Figure 2-94. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-19.3'
          >Figure 2-95. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-20'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-20.1A'
          >Figure 2-96. Testing<?/hotspot></item>
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-21'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-22'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-22.1'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-22.2'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-22.3'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-22.4'
          <item><?hotspot color="blue" href='\ch2sec3.sgm!'2-24.2.1A'
          >Figure 2-97. Testing<?/hotspot></item>
          >Figure 2-98. Testing<?/hotspot></item>
          Thanks for the help. <smiles>Max
            Oct 15, 2004#5
            May be I'm looking at this the wrong way. If I had this string
            <item><?hotspot color="blue" href=__!'2-24.2.1A' >Figure 2-97. AN/TPS-59 (V)3<?/hotspot></item> >Figure 2-98. AN/TPS-63<?/hotspot></item>
            Is there a way to say
            If figure appears more than once, copy item and paste?
              Oct 16, 2004#6
              That nothing happens on the second testfile is the reason, why I have written the first find outside the loop. So the macro exits without changing anything, if executed by mistake on a different file where the find string is not found.
              Update the macro by modifying the find expression and it will work on all your files:
              Find RegExp "<item><^?hotspot color="blue" href=*$"
              IfNotFound
              ExitMacro
              Cut
              Key DEL
              IfCharIs ">"
              Key HOME
              Key DOWN ARROW
              IfNotFound
              ExitMacro
              Cut
              Key DEL
              74
              74
                Oct 18, 2004#7
                Thank you for your response.
                I tried looking at the input from a different stand point and realized there was something all the figures had in common when they needed to have the leading item information added...each figure consistently had </item> > Figure. So using this as my guide I created this script which has worked fabulously. Thank you for all your help! Max
                :D
                UnixReOn
                Find RegExp "^([<]item[>].*'.*')"
                IfNotFound
                Key HOME
                Find RegExp "[<][/]item[>] [>]Figure.*.*"
                Replace All "</item>^p^c > Figure"
