Automatically close tags
    May 23, 2007#1
    Hello
    Can i configure the UltraEdit 13.00, so that when i type the ">" of <html>, the close-tag "</html>" will automatically be added?
    I searched in the forums and at some searchengines, but i havent found help.
    Thanks for help!
    Daniel
    344
      May 23, 2007#2
      You can write a simple small macro, that you can assign e.g. to "ctrl-shift->".
      Automatically would be strange. What happens if you really want to write <html> ?
      Macro looks like this:
      UnixReOn
      Key Ctrl+LEFT ARROW
      Key Ctrl+RIGHT ARROW
      rds Bego
        May 23, 2007#3
        First thanks for your help, but...
        Bego wrote:Automatically would be strange. What happens if you really want to write <html> ?
        When I write <html>, it would be nice when UE add </html> and but the cursor between <html> and </html>, so that I dont have to write the closing-tag.
        I write <html> and get <html></html>.
        Maybe you have not understood what I mean. My English is not that good.
        Daniel
        344
          May 23, 2007#4
          Your description really was strange. But now I got you.
          Take this one:
          UnixReOn
          Key Ctrl+LEFT ARROW
          Key Ctrl+LEFT ARROW
          Key Ctrl+LEFT ARROW
          Key Ctrl+LEFT ARROW
          Key RIGHT ARROW
          EDIT: At my example, write "<html" without the > and then let it run.
          You can do similar with tags... somehow....
          rds Bego
            May 23, 2007#5
            Thank alot Bego, that works nice!
            Daniel
              Nov 22, 2007#6
              UnixReOn
              Find Up "<"
              Key RIGHT ARROW
              SelectWord
              Find ">"
              Key LEFT ARROW
              Key RIGHT ARROW
              Find Up "<"
              Key LEFT ARROW
              Hey, I wrote this macro. It also works fine even if you have attributes in your tag. Try it.
              344
                Nov 24, 2007#7
                Yes, even better :-)
                  Jun 05, 2008#8
                  The last macro mentioned did not work so well for me (maybe because of changes in the newer version of UltraEdit), but it was close. Here's my version:
                  UnixReOn
                  Find Up "<"
                  Key RIGHT ARROW
                  SelectWord
                  Find ">"
                  Find ">"
                  Key LEFT ARROW
                  Find Up "<"
                  Key LEFT ARROW
                  Find ">"
                  Key RIGHT ARROW
                    May 18, 2011#9
                    Actually the recently opened tag gets closed but it is not closing the previous tag on the next execution of the Macro.
                    Kindly, update the coding asap
                    For EX:-
                    If we open <p> tag and <b> tag as below
                    <p> sample <b> document for reference
                    And when we apply the macro we get the output as
                    <p> sample <b> document for reference </b></b>
                    Here we need to close both the <p> and <b> Tags.
                    6,616548
                      May 31, 2011#10
                      vastek, the macros posted here are designed for closing just the last tag. For a task like you posted a script would be necessary because with a macro that is impossible to realize. Even a script solution is hard to code because lots of other tags can be between the opening tag which should be closed and the current position of the cursor. Some of these embedded tags can be empty elements like <br> or <img src="...">, others can be block elements with closing tag optional in HTML, but required in XHTML like <li>, <p>, <td>, ... So the script would need to read in worst case entire structure of the entire HTML or XHTML file, interpret it depending on type of file, handle error conditions like missing closing tags or wrong order of closing tags (<b><i>...</b></i> is allowed in HTML, but not in XHTML) to finally find out if a closing tag is missing and which one.
                      BTW: UEStudio has this feature built-in. It's available in the HTML toolbar and has the name HTML Close Tag and which works also for XHTML and XML files. So if you need that often, you should think about upgrading from UltraEdit to UEStudio.
                      For UltraEdit there is also a script solution written by Rob Dawson and linked on Codebox Software - List of Pages with title UltraEdit Tag Completion Script.
                        Jul 05, 2011#11
                        Dear Mofi,
                        Thanks for your reply and yes it is used only for closing last tag.
                        I got the required info. Thanks for your effort.
