delete lines that have a number below a certain threshold
    Oct 10, 2007#1
    I have a large text file that has 3 numbers per line (latitude, longitude, elevation), space-delimited. Example rows are:
    -75.00000 42.50000 518
    -74.99583 42.50000 505
    -71.40000 40.70417 -60
    The first 2 numbers stay in the -75 & 42 range. I need to DELETE all lines where the 3rd value is less than -1500. I can handle string replacement OK, but I'm not sure about numbers.
    Any ideas?
    -Wes
      Re: delete lines that have a number below a certain threshol
      Oct 10, 2007#2
      Following macro should do the job.
      The first replace deletes all lines with third number less than -10000.
      The second replace deletes all lines with third number in range of -2000 to -9999.
      The third replace deletes all lines with third number in range of -1500 to -1999.
      The macro property Continue if a Find with Replace not found or Continue if search string not found must be checked for this macro.
      TrimTrailingSpaces
      Find RegExp "%* * -[1-9][0-9][0-9][0-9][0-9]+^p"
      Replace All ""
      Find RegExp "%* * -[2-9][0-9][0-9][0-9]^p"
      Replace All ""
      Find RegExp "%* * -1[5-9][0-9][0-9]+^p"
      Replace All ""
        Dec 10, 2007#3
        Hi Again,
        How about if I want to replace the third number with a value of -2000, instead of deleting the line (the rest of the conditions the same)...something like this?
        Replace All "^1 ^2 -2000"
        Thanks again!
          Dec 10, 2007#4
          You have forgotten the round brackets to tag the string part which should not be modified by the replaces.
          TrimTrailingSpaces
          Find RegExp "%^(* * -^)[1-9][0-9][0-9][0-9][0-9]+^p"
          Replace All "^12000"
          Find RegExp "%^(* * -^)[2-9][0-9][0-9][0-9]^p"
          Find RegExp "%^(* * -^)1[5-9][0-9][0-9]+^p"
            Dec 20, 2007#5
            Last question - and this I'm not sure can be done in UltraEdit. I realize what I now need is Perl or Javascript. But I'll ask anyway...
            Is it possible to add 2000 to the 3rd number? (My range for the 3rd number is 2000.0 to -2000.0)
            For example:
            -70.098333 37.823333 -1956.1
            becomes:
            -70.098333 37.823333 43.9
            Mofi, thank you in advance...you really saved my hide.
            262
              Dec 20, 2007#6
              skeletrooper wrote:Last question - and this I'm not sure can be done in UltraEdit. I realize what I now need is Perl or Javascript.
              You haven't mentioned what UE version you use - but since you mention javascript, are you possibly using version 13 and above ?
              In a javascript it would be pretty simple, though not necessarily "macro fast".
                Dec 20, 2007#7
                Well I decided not to wait for you answer about your UE version as I needed a small "coffee break challenge" ;-)
                Below you'll find a script that will work for UE version 13 and above that adds 2000 to the last number.
                If you still need some of the macro tasks performed on your data (delete lines and stuff) before adding 2000 remember to run these macros before or try and incorporate the same logic into the script.
                // Support function: remove starting and ending / as UE does not recognize these for regexp
                RegExp.prototype.toUEregexp = function() { return this.toString().replace(/^\/|\/$/g, ""); };
                // First ensure last line ends with CRLF
                var ColNum = UltraEdit.activeDocument.currentColumnNum;
                if (typeof(UltraEdit.activeDocumentIdx) == "undefined") ColNum++;
                if (ColNum>1) {
                // First go to top of document
                UltraEdit.perlReOn(); /* Let's use Perl regexp syntax */
                UltraEdit.activeDocument.findReplace.regExp = true;
                //Find lines like:
                //-70.098333 37.823333 -1956.1
                //We use 2 tagged expressions grouping like this (shown with [] pairs)
                //[-70.098333 37.823333 ][-1956.1]
                var regexpFind = /^(.*? .*? )(.*?)$/;
                // Loop and search for pattern
                while ( UltraEdit.activeDocument.findReplace.find(regexpFind.toUEregexp()) ) {
                	// get line
                	var line = UltraEdit.activeDocument.selection;
                	// now parse into variables with perl regexp
                	var [, wLineStart,wNumber] = regexpFind.exec(line);
                	// Add 2000 to number (toFixed because of the buggy Math in javascript)
                	wNumber = (Number(wNumber) + 2000).toFixed(1);
                	// Write result back on top of the selected line:
                	UltraEdit.activeDocument.write(wLineStart+String(wNumber));
                // reposition to top
