Find the file and copy file/path name
5
    Nov 07, 2007#1
    Hi all,
    all my project related files are in say c:\Hsb\ folder and I've the file name which I need to search inside this folder. There are several sub-folders in Hsb folder. Can I search for the file name and copy the entire path including filename thru macros?
    It will help me a lot. Please respond if u know the solution.
    thanx.
      Nov 07, 2007#2
      The following macro assumes that the file name which you want with full path is in the current clipboard and will be replaced in the clipboard with the full file name.
      For details about the first part of the macro see Run Macro on all files within folder. You have not posted all necessary information to post here the macro which surely works for you.
      Replace the second line of the macro with following if you use a project.
      FindInFiles ProjFiles "" "" ""
      The macro property Continue if a Find with Replace not found or Continue if search string not found must be checked for this macro.
      FindInFiles Recursive "C:\Hsb\" "*" ""
      Find MatchCase Up "Search complete, found "
      NextWindow
      DeleteLine
      UnicodeToASCII
      Find RegExp "%*^c*$"
      CloseFile NoSave
      5
        Nov 11, 2007#3
        Thanks Mofi,
        I am sure that it will work for me. I need only to update my UltraEdit which is currently of version 10.10c. Thanks a lot. :)  :D
