Update default values in file 1 with values in file 2
    Mar 18, 2008#1
    I'm not sure if this is possible with UltraEdit.
    I have two files, a program file and a parameter file. In the program files there are default parameter values, in the parameter file there are true parameter values.
    My question is, is it possible to replace the default parameter vaules with the parameter value in the second file?
    example.
    file 1 (program file):
    BEGIN DSJOB
       Identifier "defaultvalue1"
       DateModified "2008-02-22"
       TimeModified "08.52.00"
       BEGIN DSRECORD
          Identifier "ROOT"
          OLEType "CJobDefn"
          Readonly "0"
          Name "defaultvalue1"
          Description "Interface Data: Bepalen controlegetallen van de ingelezen interface."
          NextID "2"
          Container "V0"
          FullDescription =+=+=+=
          JobVersion "36.0.0"
          ControlAfterSubr "0"
          Parameters "CParameters"
          BEGIN DSSUBRECORD
             Name defaultvalue1
             Prompt "defaultvalue2"
             ParamType "defaultvalue3"
             ParamLength "defaultvalue4"
             ParamScale "defaultvalue5"
          END DSSUBRECORD
    Same file again without the preceding characters, but with bold highlighting the important values which should be replaced.
    BEGIN DSJOB
    BEGIN DSRECORD
    Identifier "ROOT"
    OLEType "CJobDefn"
    Readonly "0"
    NextID "2"
    Container "V0"
    JobVersion "36.0.0"
    BEGIN DSSUBRECORD
    Name defaultvalue1
    END DSSUBRECORD
    file2 parameter file: (has no preceding white-spaces)
    defaultvalue1 = interface1
    defaultvalue2 = testting
    defaultvalue3 = 0
    defaultvalue4 = 0
    defaultvalue5 = 0
    The program file is not a large files approximatly 2 MB, parameter file is less, approximatly 500 KB.
    Version of UE is V10.20c
    I am new to this forum and writing macros as well :)
    If you know how to write the macro, then please help me.
      Mar 19, 2008#2
      Yes, this is possible with a macro. I guess there are more such blocks in both files and because defaultvalue1 must be replaced 3 times per block a really general search and replace method cannot be used. The following works according to your examples. If you need an explanation, I can write it at weekend.
      By the way: Is the second Name defaultvalue1 really with double quotes? The macro currently expects that.
      Bottom
      IfColNum 1
      TrimTrailingSpaces
      Find "^p^p"
      Replace All "^p"
      IfNotFound
      Find RegExp "%*= "
      Replace All ""
      SelectAll
      CloseFile NoSave
      IfCharIs "#"
      Delete
      Key END
      DeleteLine
      Find "Identifier "defaultvalue1""
      Replace "Identifier "^c""
      Find "Name "defaultvalue1""
      Replace "Name "^c""
      Find "Name defaultvalue1"
      Replace "Name ^c"
      Key END
      DeleteLine
      Find "Prompt "defaultvalue2""
      Replace "Prompt "^c""
      Key END
      DeleteLine
      Find "ParamType "defaultvalue3""
      Replace "ParamType "^c""
      Key END
      DeleteLine
      Find "ParamLength "defaultvalue4""
      Replace "ParamLength "^c""
      Key END
      DeleteLine
      Find "ParamScale "defaultvalue5""
      Replace "ParamScale "^c""
        Mar 27, 2008#3
        Dear Mofi,
        Thank you so much for the example.
        If you can make a explanation i will appreciate it.
        Regards,
        Cemmie
          Mar 30, 2008#4
          Here is the macro code again with comments (lines starting with //) and indenting. It can be best read saving it into a file with the extension UEM and using the syntax highlighting for UE Macro source code files. For details see my sticky Macro examples and reference for beginners and experts topic.
          //  Make sure the last line of the parameter file has a line termination.
              Bottom
              IfColNum 1
          //  Delete all spaces and tabs at end of every line and all blank lines.
              TrimTrailingSpaces
                  Find "^p^p"
                  Replace All "^p"
                  IfNotFound
          //  Delete at every line everything before equal sign and the following space.
          //  Now only the values which should be inserted into the other file remain.
              Find RegExp "%*= "
              Replace All ""
          //  Copy this parameter list into user clipboard 9 and close the paramter file
          //  without saving the changes. The program file get automatically the focus.
              SelectAll
              CloseFile NoSave
          //  At top of the program file insert the parameter list and additionally the
          //  character # below at start of the first line in the program file. It is
          //  required that there is no value in the parameter list which starts with #.
          //  Run the following loop until character # is found at start of the line
          //  respectively at top of the file. If found, delete this inserted character
          //  and exit the loop.
                  IfCharIs "#"
                      Delete
          //  Select the first parameter value (from defaultvalue1 of current block),
          //  copy it to user clipboard 9 and delete whole line.
                  Key END
                  DeleteLine
          //  Search for first occurrence of the string below and replace string
          //  "defaultvalue1" with the parameter value in ative clipboard.
          //  Make the same single replace for the other 2 occurences of "defaultvalue1"
          //  in the current section.
                  Replace "Name "^c""
                  Replace "Name ^c"
          //  Make the single replace with the same method for the other 4 parameter
          //  values. The only difference is that they exist only once per section.
                  Key END
                  DeleteLine
                  Key END
                  DeleteLine
                  Key END
                  DeleteLine
                  Key END
                  DeleteLine
          //  At this point the 5 parameter values have replaced the templates
          //  in the first section where "defaultvalue1" was still found. Continue
          //  now the the next 5 parameter values in the next section.
          //  At the end after processing all parameter values clear user clipboard 9
          //  to free RAM and switch back to the standard Windows clipboard.
