Select to Beginning of Paragraph
    Mar 21, 2010#1
    I am trying to copy textpad's built-in behaviour in ultraedit 16.00.
    I have the text as below
    step 1: When I place my cursor at the second h of line 11, and press ctrl+shift+Up arrow, I want the selection as below
    step 2: Then when I press ctrl+shift+up arrow again, I want the selection to extend one paragraph upward, as
    I am using the macro,
    PerlReOn
    Find RegExp Up Select "^\s*\n"
    SelectToTop
    with a keyboard hotkey = ctrl+shift+Up Arrow
    But at step 2, it doesn't extend the selection, instead selects only the above paragraph as
    Can someone help with the macro ?
      Mar 22, 2010#2
      interestingly for me it works in UltraEdit 10.10c with the macro slightly modified:
      Find RegExp Up Select "%[ ^t]++^p"
      SelectToTop
        Mar 22, 2010#3
        Bernd is right, his macro using the UltraEdit regex engine works, also with UE v16.00.0.1032.
        I tested this manually and found out that when using the Perl regular expression engine for a Find Select upwards, the existing selection is not recognized because of wrong cursor location after searching upwards (at bottom end of selection (= beginnig of search) instead at top end (= end of search)) while doing multiple Find Select downwards with the Perl engine works. With UltraEdit and Unix regex engines both directions work. I reported this issue by email to IDM support. As workaround use the macro written by Bernd.
        Edited on 2010-08-31: The problem with Find Select upwards not retaining existing selection when using the Perl regular expression engine was fixed with UltraEdit v16.20.0.1009.
          Mar 22, 2010#4
          Thanks Bernd and Mofi.
