Backup file locations
    Dec 14, 2006#1
    Under the options menu there is a checkbox for create backup files but I can't find a reference as to where these files are located when performing a compare.
      Dec 15, 2006#2
      A simple test would have also answered your question.
      The configuration option Create backup copy for files creates a copy of a file before saving modifications in the same directory by appending ".bak" to the original name of the file.
      For example:
      C:\Temp\Test\Test.txt
      is backed up as
      C:\Temp\Test\Test.txt.bak
      The configuration option Create backup copy of zip archives for zip archives creates a copy of a zip archive before repacking a zip archive in the same directory by inserting "Bak" before ".zip".
      For example:
      C:\Temp\Test\Test.zip
      is backed up as
      C:\Temp\Test\TestBak.zip
        Dec 15, 2006#3
        I thought this was the case. I wanted to confirm as I did a folder compare and accidentally accepted the changes including my backup files. The program doesn't appear to generate backup files if the files being compared have a .bak extension.
