Shift+F10 not showing context menu in V12
24
PostMar 23, 2006#1
Hi
In v11 I could launch the context menu with Shift+F10. After having installed V12 this does not work anymore. Does anyone have any ideas?
tx
6,823625
New default key assignments in UltraEdit v12.00
PostMar 23, 2006#2
During beta test phase I required to list new key assignments in readme.txt, so users with many personal key assignments can more easily detect and fix duplicate assignments of a hot key to different functions after upgrade. IDM has done it and I also get the full list of new default assignments and functions for UltraEdit v12.00 and UEStudio v5.10.
I also required a tool or build in function for UltraEdit and UEStudio to scan the current key mappings and generate a text file with a list of all function names and their hot key(s) assigned. The customer support employees of IDM would like it too, which increases the chance to get such a tool or built in function in a future version.
Back to your problem:
4 days ago as I evaluated my key mappings after the upgrade I detect that not only the new default key assignments of UltraEdit are added to the key configuration file uedit32.kbd but also the new UEStudio key assignments. This is very interesting because the functions simply do not exist in UltraEdit. Some of the UEStudio key assignments have a function tip also in UltraEdit although the functions are not available. Other UEStudio key assignments have no function tip.
As I also have done 4 days ago you have to fix now the duplicate key assignments. Shift+F10 to open the context menu is something special because it is a Windows default hot key and not a function of UltraEdit. To get back Shift+F10 as hot key for opening the context menu you have to do following:
Open the key mapping configuration dialog and look for a function which does not have any key assignment.
Now assign Shift+F10 to this function. The existing assignment of Shift+F10 from UEStudio function BuildBatchBuild will be removed.
Now remove Shift+F10 from the UltraEdit function and close the configuration dialog with OK.
Because now no function is assigned to Shift+F10 anymore the context menu will open again with Shift+F10.
For all users:
Here is the list of new default key assignments for UEStudio/UltraEdit I got from IDM:
UltraEdit Key Mapping Assignments added in v12.00
NextWindowPanel                              Ctrl+F1O
PrevWindowPanel                              Alt+F1O
EditPasteCopy                                Ctrl+Shift+V
ProfileSelectMenu                            Alt+F8
Added in V12.00, but not assigned:
FileConvUNICODEToUNICODEBigEndian
FileConvUNICODEBigEndianToUNICODE
FileConvToASCIIEscapedUnicode
FileConvFromASCIIEscapedUnicode
FileConvUserConvertTo
FileConvUserConvertFrom
FilePrintAll
ProjectCreateUsingTemplates
ProjectAddFile
ProjectAddFolder
ViewSelectFixedFont
FormatHTMLValidatorJobType
FormatHTMLValidatorOptions
FormatHTMLValidatorConfiguration
FormatXMLViewer
AdvancedImportSettings
AdvancedExportSettings
AdvancedUserTool11
AdvancedUserTool12
AdvancedUserTool13
AdvancedUserTool14
AdvancedUserTool15
AdvancedUserTool16
AdvancedUserTool17
AdvancedUserTool18
AdvancedUserTool19
AdvancedUserTool20
AdvancedUserTool21
AdvancedUserTool22
AdvancedUserTool23
AdvancedUserTool24
AdvancedUserTool25
AdvancedProjectTool11
AdvancedProjectTool12
AdvancedProjectTool13
AdvancedProjectTool14
AdvancedProjectTool15
AdvancedProjectTool16
AdvancedProjectTool17
AdvancedProjectTool18
AdvancedProjectTool19
AdvancedProjectTool20
AdvancedProjectTool21
AdvancedProjectTool22
AdvancedProjectTool23
AdvancedProjectTool24
AdvancedProjectTool25
HelpAddHelp
UEStudio Key Mapping Assignments added in v05.1
ProjectConvertor                             Shift+Alt+V
ProjectManager                               Shift+Alt+M
ProjectCVSCheckout                           Shift+Alt+H
ProjectCVSUpdate                             Shift+Alt+U
ProjectCVSCommitEx                           Shift+Alt+Q
ProjectCVSTag                                Shift+Alt+T
ProjectCVSImport                             Shift+Alt+I
ProjectCVSExport                             Shift+Alt+E
ProjectCVSManager                            Shift+Alt+A
BuildCompile                                 Shift+F7
BuildBuild                                   Shift+F8
BuildRebuild                                 Shift+F9
BuildBatchBuild                              Shift+F10
BuildClean                                   Shift+F11
BuildDebugger                                Shift+F12
BuildRegenerateMakeFile                      Shift+F4
SolutionNew                                  Shift+Alt+W
SolutionOpen                                 Shift+Alt+P
SolutionClose                                Shift+Alt+L
SolutionAddProject                           Shift+Alt+J
SolutionRemoveProject                        Shift+Alt+X
IntellitipFindSymbolDef                      Ctrl+Alt+F12
Added in V05.1, but not assigned:
BuildRun
BuildCommands
BuildSelectCompiler
BuildCompilerOptions
BuildOptions
BuildSetCompilerPaths
BuildDisplayTagList
ScriptRubyRun
ScriptRubyCheckSyntax
ScriptRubyCommandOptions
FilePrintAll
ProjectAddDll
ProjectAddFile
ProjectAddFolder
ProjectCVSUpdateEx
ViewSelectFixedFont
FormatXMLViewer
AdvancedUserTool11
AdvancedUserTool12
AdvancedUserTool13
AdvancedUserTool14
AdvancedUserTool15
AdvancedUserTool16
AdvancedUserTool17
AdvancedUserTool18
AdvancedUserTool19
AdvancedUserTool20
AdvancedUserTool21
AdvancedUserTool22
AdvancedUserTool23
AdvancedUserTool24
AdvancedUserTool25
HelpAddHelp
