C# UTF-8 Files being misread as DOS?
112
112
    Aug 14, 2005#1
    I'm outputting files from C# - which I'm new to. I'm using a StreamWriter (which is supposed to default to UTF-8 encoding).
    When I look at these files with UE 11.10 the guillemet characters are incorrectly rendered:
    <Persistence>«Unknown»</Persistence>
    If I use one of the conversions (such as UTF-8 to ASCII), they are rendered correctly:
    When I first open the file, the status bar shows DOS. Should it?
    Is it a rendering or an encoding problem?
    I've had a search of the forum but none of the UTF-8 posts seem to be directly relevant.
    Cheerz,
    Paolo
    PS: Some further testing shows UltraCompare will identify the files correctly as UTF-8 with correct rendering.
    6,616548
      Aug 15, 2005#2
      Have you enabled Auto detect UTF-8 files at the general configuration page?
      Read in help of UltraEdit the chapter Unicode and UTF-8 Support for details.
      112
      112
        Aug 15, 2005#3
        Yes,
        That did it. Thanks Mofi! I had other UTF support enabled, but I must have accidentally unchecked it...
        Cheerz,
        Paolo
