How can I change the color of an entire column ?
    Nov 15, 2004#1
    How can I change the color of an entire column, and is there a way to setup particular columns to always have a certain color ?
      Nov 16, 2004#2
      UltraEdit is a byte oriented text editor and not a cell (columns / rows) oriented spreadsheet program or a word proccessing program with table support. So you can not specify colors for different columns.
      10
        Nov 17, 2004#3
        The only thing you can do is set 2 column markers - thin vertical lines - in the View menu.
