How to view files with long lines without wrap?
    Jan 31, 2005#1
    I have a problem. A client wants to send me files that are over 4097 characters per line (5502 chars in this case). How do I get UE to display the entire line rather than wrapping at 4097 characters?
    I would really appreciate some help.
    Thanks!
    206
      Feb 01, 2005#2
      Advanced > Configuration > General > Display
      Allows you to set the value as high as 20000
      Software For Metalworking
        Feb 01, 2005#3
        Thank you. But I may need to upgrade, I have version 7.20 and there is no Display entry under the General tab. But it is good to know it IS possible.
          Feb 01, 2005#4
          You need at least V10.10 to increase Max Columns= up to 20000 at section [Settings] in the ini-file or with the general configuration page.
            Feb 01, 2005#5
            Thanks Mofi. I downloaded the latest version and with the info from you guys the problem is solved!
              Mar 01, 2005#6
              I need to be set at 100,000
              How do I do this???
              Please help.
              63
              Advanced UserAdvanced User
              63
                Mar 01, 2005#7
                Hi brian.simpson
                Send a email to IDM support and make a suggestion for a new feature.
                Let us know what they say.
                Good Luck
