Output windows limit in UEStudio v5.50a
    Jun 20, 2006#1
    I have following problem:
    I want search in my project, the mean
    Suche abgeschlossen. Fundstellen: '#if' 1020 Einträge. (208 Datei[en])
    found 1020 entry in 208 files
    BUT I saw only 100 lines. :evil: :evil: :evil: :?: :?: :?:
    Have anyone a Help for me??
    PLEASE
    thx
    mick
    Version 5.50+3
    6,614548
      Jun 20, 2006#2
      Yes, you are right. This is a bug of UEStudio. I could reproduce it with v5.50+3 and v5.50a. The output windows are limited to 101 lines. Please send a bug report email to IDM support.
      Results to Edit Window works in UEStudio.
      UltraEdit v12.10a does not have this problem. It has contained the correct amount of 10960 lines as I tested it with the same search as with UEStudio. So it must be a bug in UEStudio with the 4 output windows.
        Jun 20, 2006#3
        Hallo,
        vielen Dank,
        ich habe es allerdings erst plötzlich festgestellt.
        Gruß
        MiHo
