mapped network drive = FREEZE?
33
    Aug 02, 2006#1
    I have a network drive mapped to N:. This works fine in UltraEdit. My main project uses this drive.
    When trying to add this drive to a project in UEStudio, or open a project that has this drive within it, the entire application freezes and does not come back.
    Is this a common problem?
    6,619549
      Aug 03, 2006#2
      I guess, something is searched on the drive which does not exist. It should be well known that Windows makes 3 repeats each with a 30 seconds timeout when accessing something (files, printers, ...). Use the free tool Filemon to find the problem.
        Jul 14, 2007#3
        This is a problem I'm seeing with UES6 whenever I close the app on a file that is on a mapped drive that later is unavailable.
        UES will not startup and just hangs... I've not yet found a workaround to resolve the issue but basically it's a pain in the a**.
        Ahah... ok have a solution..
        You need to do the following:
        - Make sure UEStudio is not running.
        - Start -> Run -> regedit
        (This opens regedit but be careful you can seriously screw up your PC if you don't know what you're doing!)
        - Navigate to: HKCU -> Software -> IDM Computer Solutions -> UEStudio -> Recent File List
        - Delete all the file references [NOT the (Default) key]
        - Close the regedit window
        - Open a project by double clicking on the prj file or right click a file and choose to "open with.." and use UEStudio.
        Your mileage may vary but this worked for me so at least it gives you something of a clue.
        Note: HKCU = HKEY_CURRENT_USER
        6,619549
          Jul 14, 2007#4
          websnail, have you also enabled Reload files previously open on startup at Configuration - File Handling - Load?
          Because without this setting, it should be no problem when a recently used file is currently not available because it is on a computer which is currently not available on the network.
          And for all other users: websnail has enabled Use Registry for settings (not INI file) at Configuration - Application Layout - Advanced because by default the recent file list is stored in uestudio.ini.
