alphabetical order sequence after specific text
49
    Mar 22, 2016#1
    how to alphabetical order sequence after specific text?
    If found
    "sec@@"
    "sec@@"
    "sec@@"
    "sec@@"
    "sec@@"
    "sec@@"
    "sec@@"
    "sec@@"
    replace with
    "secA"
    "secB"
    "secC"
    "secD"
    "secZ"
    "secAA"
    "secBB"
    "secCC"
    6,616548
      Mar 23, 2016#2
      The script code is so easy for this task that I save time and don't comment it.
         UltraEdit.columnModeOff();
         UltraEdit.perlReOn();
         var asCharacters = ['A','B','C','D','E','F','G','H','I','J','K','L','M',
                             'N','O','P','Q','R','S','T','U','V','W','X','Y','Z'];
         var nCharCount=1;
         var nCharacter=0;
         while(UltraEdit.activeDocument.findReplace.find("(?<=sec)@+"))
            var sIdentifier="";
            for (var nCount=0; nCount < nCharCount; nCount++)
               sIdentifier+=asCharacters[nCharacter];
            UltraEdit.activeDocument.write(sIdentifier);
            if (++nCharacter >= asCharacters.length)
               nCharacter=0;
               nCharCount++;
      The character array can be modified to whatever you want.
      49
        Mar 24, 2016#3
        Thanks Mofi. :P
