Search for a string having number and increment the found number
5
    Aug 30, 2016#1
    Hi All,
    I want to make a script which will search for a sting having numbers and increment the found number.
    Say, below is the text in the opened file
    #define APP_VER       "10.0.55"
    #define APP_NAME 	"[AddonName]"
    #define APP_TITLE 	"[AddonName]"
    I can search for the "APP_VER" and also get the number "10.0.55", but can not find any Perl script or function to increment .55 to .56.
    Please advise.
    Regards,
    Anand
    6,616548
      Aug 30, 2016#2
      Here is the comment code for this UltraEdit script:
         // Remember current position of caret in active file.
         var nLine = UltraEdit.activeDocument.currentLineNum;
         var nColumn = UltraEdit.activeDocument.currentColumnNum;
         UltraEdit.ueReOn();
         // Search case-sensitive with a simple UltraEdit regular expression for
         // the line containing the definition of the application version number.
         if (UltraEdit.activeDocument.findReplace.find('#define +APP_VER[^t ]+"[0-9.]+"'))
            // Cancel the selection by moving caret one character to right.
            // Select with another UltraEdit regular expression search in
            // upwards direction just the last number of the version number.
            UltraEdit.activeDocument.findReplace.find('[0-9]+');
            // Convert the selected number from string to integer using decimal system.
            var nVersionNumber = parseInt(UltraEdit.activeDocument.selection,10);
            // Increment the version number by 1.
            nVersionNumber++;
            // Write the incremented number converted back from integer to string
            // into the file with overwriting the still selected version number.
            UltraEdit.activeDocument.write(nVersionNumber.toString(10));
         // Restore initial position of caret in active file.
         UltraEdit.activeDocument.gotoLine(nLine,nColumn);
      5
        Aug 31, 2016#3
        Hi Mofi,
        Thanks a lot for the script. It is working perfectly.  :D
        parseInt() was the function I needed.
        In some of my codes I have version number like below:
        #define APP_VER         "10.0.449 Beta"
        Since "Beta" is added to it, the script needed some modification. I added the code for it and also added output window message so that I know it has done the job. Below is the final script.
           UltraEdit.ueReOn();
           if (UltraEdit.activeDocument.findReplace.find('#define +APP_VER[^t ]+"[0-9.. A-Za-z]+"'))
          UltraEdit.outputWindow.write("Old number "+nVersionNumber.toString());
              nVersionNumber++;
          UltraEdit.outputWindow.write("New number "+nVersionNumber.toString());
        I will try to upload it to the script section, where I uploaded "BoxBracketToComments.js", for the benefit of UltraEdit users.
        Thanks again for your help.
        Regards,
        Anand
        6,616548
          Aug 31, 2016#4
          Better than "[0-9.. A-Za-z]+" which contains unnecessary the point twice would be "[0-9.]+*" as the asterisk in UltraEdit regular expression syntax means 0 or more characters except newline characters.
          5
            Aug 31, 2016#5
            Thanks, it did the trick. Also search is shorter now.
            Regards,
            Anand
