How to split a single file into multiple several files by script
49
    Feb 11, 2017#1
    Hi friends
    How to split a single file into multiple several files by script?
    I want a script which run with file path and split file in multiple files.
    At first put file path next the beginning tag in file like <hr class="sigil_marker"/>.
    File split by <hr class="sigil_marker"/> beginning tag with appropriate closing tag, which open adobe <hr class="sigil_marker"/> and those open tag insert next split file.
    I have uploaded an example file and the result files after splitting the example file. Both files were deleted later.
    6,614548
      Feb 13, 2017#2
      Here is the script for this task.
      function CreateChapterFile ()
         UltraEdit.newFile();
         UltraEdit.activeDocument.write('<html>\r\n<body>\r\n<div class="chapter">\r\n');
         UltraEdit.activeDocument.write('</div>\r\n</body>\r\n</html>\r\n');
         var sChapter = g_nChapter.toString(10);
         sChapter = sLeadingZeros.substr(0,sLeadingZeros.length-sChapter.length) + sChapter;
         var sFileNameWithPath = g_sFilePath + sChapter + "_" + g_sFileName + "-" + sChapter + ".xhtml";
         UltraEdit.saveAs(sFileNameWithPath);
         var nDocIndex = UltraEdit.activeDocumentIdx;
         UltraEdit.ueReOn();
         UltraEdit.document[nDocIndex].findReplace.mode=0;
         UltraEdit.document[nDocIndex].findReplace.matchCase=true;
         UltraEdit.document[nDocIndex].findReplace.matchWord=false;
         UltraEdit.document[nDocIndex].findReplace.regExp=false;
         UltraEdit.document[nDocIndex].findReplace.searchDown=true;
         UltraEdit.document[nDocIndex].findReplace.searchInColumn=false;
         if(UltraEdit.document[nDocIndex].findReplace.find('<div class="chapter">'))
            var g_nChapter  = 1;
            var g_sFilePath = UltraEdit.document[nDocIndex].path.replace(/^(.+\\).+$/,"$1");
            var g_sFileName = UltraEdit.document[nDocIndex].path.replace(/^.+\\(.+)\.xhtml$/,"$1");
            var nLastLine;
            var nFirstLine = UltraEdit.document[nDocIndex].currentLineNum + 1;
            var sLeadingZeros = "00";
            UltraEdit.selectClipboard(9);
            while(UltraEdit.document[nDocIndex].findReplace.find('<hr class="sigil_marker"/>'))
               nLastLine = UltraEdit.document[nDocIndex].currentLineNum;
               UltraEdit.document[nDocIndex].gotoLine(nLastLine,1);
               UltraEdit.document[nDocIndex].gotoLineSelect(nFirstLine,1);
               UltraEdit.document[nDocIndex].copy();
               CreateChapterFile();
               nFirstLine = nLastLine + 1;
               UltraEdit.document[nDocIndex].gotoLine(nFirstLine,1);
               g_nChapter++;
            if(UltraEdit.document[nDocIndex].findReplace.find("</body>"))
               nLastLine = UltraEdit.document[nDocIndex].currentLineNum - 1;
            UltraEdit.document[nDocIndex].top();
            UltraEdit.clearClipboard();
            UltraEdit.selectClipboard(0);
      The separator tag <hr class="sigil_marker"/> is not written into any created file.
