List of scripts in pulldown menu - other names?
1581
1581
    Mar 16, 2017#1
    I loaded some scripts, and the entries in the main menu are displayed with filenames:
    blockcomment.js
    header.js
    Is it possible to assign free, clear names like
    Comment out blocks
    Add header to all files
    Peter
      Mar 16, 2017#2
      There is currently (UE for Windows v24.00.0.56) only the possibility to rename file blockcomment.js to Comment out blocks.js and file header.js to Add header to all files.js.
      A description can be entered for each script added to the script list (without or with hotkey/chord), but this description is only displayed in the dialog window for modifying the script list.
      It would be perhaps a good idea to send a feature request email to IDM support for a Script List view context menu option to display either file name of script with hotkey/chord or alternatively the descriptions of the scripts. In case of no description specified for a script in script list, the view should show the file name (and hotkey/chord) with enabled showing the script descriptions.
      Well, it would make also sense to do not show the file extension .js in menu and in Script List view. That could be also suggested by email to IDM support.
