Reading from a file into a variable
681
Advanced UserAdvanced User
681
    Aug 10, 2017#1
    Hi there,
    I want to read values into variables. A sample of the file format is at bottom. The only scripting command that I can find to read from the file is:
    var char = UltraEdit.activeDocument.currentChar;
    Is this what I should use?
    Many thanks for any reply.
    00:28:24,2015-11-06 23:53:11 +0000,Conclusion,,Green,MT42 Beanstalk,MTX
    00:25:47,2015-11-06 23:49:56 +0000,Stacked,,Green,MT42 Beanstalk,MTX
    6,616548
      Aug 11, 2017#2
      Better is to make a selection and use var sString = UltraEdit.activeDocument.selection to assign selected text to variable sString or work directly with the string variable UltraEdit.activeDocument.selection.
      On small files up to 20 MiB it is also possible to use something like:
         // Select everything in active file.
         if (UltraEdit.activeDocument.isSel())  // Is the file not empty?
            // Determine line termination type used in active file.
            var sLineTerm;
            if (UltraEdit.activeDocument.lineTerminator < 0) sLineTerm = "\r\n";
            else if (UltraEdit.activeDocument.lineTerminator == 1) sLineTerm = "\n";
            else sLineTerm = "\r";
            // Load entire file content as array of strings into memory with
            // each string being a line from file without line termination.
            var asLines = UltraEdit.activeDocument.selection.split(sLineTerm);
            // Do something with the lines in the array of strings.
            // Join the lines back to a single string (block) and
            // overwrite entire file content with the modified lines.
            UltraEdit.activeDocument.write(asLines.join(sLineTerm));
      681
      681
        Aug 11, 2017#3
        Thank you Mofi.
