write special character
    Apr 04, 2007#1
    Hi
    I tried the new scritps for the first time.
    I made a script that should add the character em-dash (hex 97) to the document. This is the line:
    UltraEdit.activeDocument.write("—");
    21
      Apr 04, 2007#2
      I tried this script and it works.
      UltraEdit.hexOff;
      UltraEdit.ueReOn();
        Apr 04, 2007#3
        Have you installed latest hotfix v13.00+4?
        By the way: If you modify a HTML file you should use the HTML entity as recommended by the HTML standard. If you use HTMLTidy to check your HTML code you will get a warning when simply inserting a — as character and not correctly encoded. The entity is —.
        Read also carefully my post at Script files can't be UTF-8? and the pages referenced there.
          Apr 04, 2007#4
          Hi
          Actually the one line code also works, but the activeDocument obviously has to be UTF-8. I had it in ASCII.
          Which is funny, because apparently you can not have the script file in unicode
