phpDocs Script
phpDocs Script
    May 15, 2007#1
    For anyone using phpDocs format to document their php Project this script file should be very useful.
    The script generates the docBlock code depending on the currently selected line.
    <?php: creates file-level block.
    class/var: creates an empty block for comments.
    function: automatically adds the listed parameters.
    existing comments: Asks for new phpDocs tag name
    The lastest version of the code can be found at
    phpDocs UltraEdit Script
      Oct 28, 2010#2
      The link is down.
      Is there a function in UE that help generating the docBlocks or is there an other script that can do it ?
      262
        Oct 28, 2010#3
        I saved a copy of the script since it was released into the public domain on May 15th, 2007.
        // Script by. Rain Style http://www.rain.com.au
        // TODO: Detect line terminators
        // Add phpDocs comment style above a function declaration/definition.
        function phpDocFunc() {
          var doc = UltraEdit.activeDocument;
          var curline;
          doc.selectLine();
          curline = doc.selection;
          curline = curline.replace(/\r|\n/g," ");    			// remove line terminators if any.
          var indent = curline.match(/^[ \t]*/);
          indent = indent[0] ? indent[0] : "";
          if(curline.match(/<\?php/)) {
          	doc.key("UP ARROW");
          	doc.key("END");
        		doc.key("RIGHT ARROW");
          	var str = Array();
          	str.push(indent+'/**');
          	str.push('*');
          	str.push('* @package');
          	str.push('* @subpackage');
          	str.push('*/');
          	for(var i in str) {
          		doc.gotoLine(0,0);
          		doc.write(str[i]+'\r\n');
          		doc.key("HOME");
          else if(curline.match(/class /)) {
          	doc.write ("\r\n"); // only valid for dos eol!
          	str = Array();
          	str.push('* ');
          	str.push('* ');
          	str.push('*/');
          	for(i in str) {
          		doc.gotoLine(0,0);
          		doc.write(str[i]+(i<str.length-1?'\r\n':''));
          else if(curline.match(/var /)) {
          	str = Array();
          	str.push('* ');
          	str.push('*/');
          	for(i in str) {
          		doc.gotoLine(0,0);
          else if(curline.match(/function /)) {
          	  // get argument list (between parenthesis)
        		  var re = /\(.*\)/;
        		  var parens = curline.match(re);
        		  // Try to extract parameters from stuff between parenthesis.
        		  // Note that 'parens.match' (below) returns an array.
        		  var params = null;
        		  if (parens) {
        		    parens = parens[0];
        		    var param_re = /\w+(?=\s*[,\)])/g;
        		    params = parens.match(param_re);
          	str = Array();
          	str.push('* ');
          	str.push('* ');
        		if (params) {
            	for (i = 0; i < params.length; ++i) {
          			str.push('* @param '+params[i]);
          	str.push('* @return ');
          	str.push('*/');
          	for(i in str) {
          		doc.gotoLine(0,0);
          else if(curline.match(/\*/)) {
          	var tag = UltraEdit.getString('Enter phpDoc tag:',1);
          	str = Array();
          	str.push(indent+'* @'+tag+' ');
          	for(i in str) {
          		doc.gotoLine(0,0);
          else {
          	str = Array();
          	str.push('   * ');
          	str.push(' */');
          	for(i in str) {
          		doc.gotoLine(0,0);
          return true;
        // Execute function defined above
        phpDocFunc();
          Oct 28, 2010#4
          Thank you very much :)
            Aug 04, 2011#5
            You can replace "\r\n" and '\r\n' with a variable obtained via UltraEdit.activeDocument.lineTerminator:
            var sLineTerm = "\r\n";           // Default is DOS.
              if (typeof(UltraEdit.activeDocument.lineTerminator) == "number") {
                if (UltraEdit.activeDocument.lineTerminator == 2) sLineTerm = "\n";
                else if (UltraEdit.activeDocument.lineTerminator == 3) sLineTerm = "\r";
            I also replaced the indent regex to match any space instead of tab only:
            var indent = curline.match(/^[\s]*/);
            I also had to replace str.push(' with str.push(indent+' to retain the indentation correctly.
            So here's my version of the script:
            // Code to Detect line terminators code and indentation messing by Echopark
              var curline;
              doc.selectLine();
                 doc.key("END");
                 var str = Array();
                 str.push(indent+'*');
                 str.push(indent+'* @package');
                 str.push(indent+'* @subpackage');
                 str.push(indent+'*/');
                 for(var i in str) {
                    doc.gotoLine(0,0);
                    doc.write(str[i]+sLineTerm);
                    doc.key("HOME");
                 doc.write (sLineTerm);
                 str = Array();
                 str.push(indent+'* ');
                 for(i in str) {
                    doc.gotoLine(0,0);
                    doc.write(str[i]+(i<str.length-1?sLineTerm:''));
                 str = Array();
                 for(i in str) {
                    doc.gotoLine(0,0);
                    var re = /\(.*\)/;
                    var params = null;
                    if (parens) {
                      parens = parens[0];
                 str = Array();
                  if (params) {
                       str.push(indent+'* @param '+params[i]);
                 str.push(indent+'* @return ');
                 for(i in str) {
                    doc.gotoLine(0,0);
                 str = Array();
                 for(i in str) {
                    doc.gotoLine(0,0);
              else {
                 str = Array();
                 str.push(indent+'   * ');
                 str.push(indent+' */');
                 for(i in str) {
                    doc.gotoLine(0,0);
              return true;
            phpDocFunc();
            6,614548
              Aug 04, 2011#6
              Nice enhancements.
              But do you know that \s is not equal [ \t]. \s is a Shorthand Character Class for whitespace characters. And the space and horizontal tab characters are not the only whitespace characters. \s includes also other whitespace characters like carriage return \r, line-feed \n, vertical tab \v and form-feed \f.
              Well, vertical tab and form-feed are usually not present in PHP source files and that \s matches also the line terminating characters does not matter for the script as is, but I suggest nevertheless to use
