Delete fast all lines containing string
5
    Mar 19, 2010#1
    Hi all:
    I'm new to the forums and new to UltraEdit. I'm looking for a way to delete lines that contain a string. I've seen plenty of discussion on this, and I've created a script to do this based on the tutorial here: http://goo.gl/JpUK .
    Problem is, it's incredibly slow. My goal is to be able to cut out repetitive lines from log files to get down to the important stuff, and in a large log, it takes way too long to run the looping tutorial script to remove all lines.
    In vim, I just use :g/<pattern>/d and this is far, far faster than running the UltraEdit script. It doesn't seem like such a simple thing should take quite so long.
    Is there a more efficient script out there somewhere that I could take a look at? Or am I overlooking something incredibly simple?
    Thanks in advance,
    Brandon
    6,614548
      Mar 19, 2010#2
      What about using a regular expression replace all executed from top of the file.
      For example using the Perl regexp engine search for ^.*your string.*\r*\n and the replace string is just an empty string.
      5
        Mar 19, 2010#3
        Beautiful. Exactly what I was looking for. Did not think to use a regEx to match a line w/ string... Duh. I was just leaving blank spaces in all my lines that had the search string.
        Thanks for the help. I modified the tutorial script I referenced in my first post to look like this, and it's much faster.
        It works, but does it look right to everyone? I am overlooking a shortcut?
        // Start at the beginning of the file
        // Search string variable used for deletion of lines
        var delString = UltraEdit.getString("Delete lines containing what?",1);
        // Turn on regular expressions to find entire line.
        UltraEdit.activeDocument.findReplace.find("^.*" + delString + ".*\r*\n");
        while (UltraEdit.activeDocument.isFound()) {
           UltraEdit.activeDocument.findReplace.replace("^.*" + delString + ".*\r*\n","");
        So, it works... But still not as fast as I'd like... Shouldn't I be able to use a script to delete all lines containing a string as fast as I can.. say... list all lines containing those strings?
        The while loop is the delay culprit here, but I couldn't get the replace all to work because it leaves too much stuff without looping to check-- When it deletes line 8, for example, line 9 becomes line 8, and it starts replacing again on the next line... So if I have a lot of instances of a string in sequential lines, it will skip every other one.
        Any ideas?
        Thank you.
        6,614548
          Mar 21, 2010#4
          The following script deletes all lines containing an entered string.
          if (UltraEdit.document.length) {
             UltraEdit.perlReOn();
             // Get string variable used for deletion of lines.
             var sUserString = UltraEdit.getString("Delete lines containing what?",1);
             // Escape every Perl regular expression character of the string with
             // a backslash to make sure that none of the characters in the entered
             // string is interpreted as regular expression character.
             var sDelString = sUserString.replace(/([$()*+.?\[\]\\{|}\^])/g,"\\$1");
             // Delete all lines containing the entered string using a Perl regexp replace.
             var sSearchString = "^.*" + sDelString + ".*(?:\\r?\\n|\\r)";
             UltraEdit.activeDocument.findReplace.replace(sSearchString,"");
          Interesting is that using var sSearchString = "^.*" + sDelString + ".*\r*\n"; results in not deleting all consecutive lines containing the string. When the JavaScript engine converts \r to 0x0D and \n to 0x0A and passes the string with these 2 bytes to the Perl engine, every second line of a block containing the search string is not deleted. But escaping \r and \n with an additional backslash to really pass to the Perl engine \r*\n works. I reported by email to IDM support the issue with not all lines deleted on first run when consecutive lines contain the searched string and just \r*\n is used instead of \\r*\\n.
          Update 1: Since UE v19.00.0.1022, first public version of UE 19.00, the search string "^.*" + sDelString + ".*\r*\n" works also for deleting consecutive lines. However, it is nevertheless better to use \\r and \\n in JavaScript strings which are search/replace strings for a Unix/Perl regular expression find/replace.
          Update 2: Even better is using var sSearchString = "^.*" + sDelString + ".*(?:\\r?\\n|\\r)"; as with this OR expression the script works for files with DOS or UNIX or MAC terminated lines.
            May 24, 2010#5
            I've been using the included script for a while now, it's actually the example provided by UE website. Every since switching to the Linux version of UE, I've been unable to run it. I keep getting the following error message:
            An error occurred on line: 17
            Script failed.
            Could anyone provide insight as to why this is happening.
            Thanks in advance.
            Nick
            // Establish our search string for the loop condition
            UltraEdit.activeDocument.findReplace.find(delString);
            // Variable to count found items
            i = 0;
            // Start with nothing on the clipboard
            UltraEdit.clearClipboard();
                 // Loop through the file, count and delete found lines
                 while (UltraEdit.activeDocument.isFound()){  //<------- line 17 (failure)
                 // We use an if statement here, because when the above "isFound" is evaluated,
                 // the script will use the last Find operation for re-evaluation instead of initiating
                 // a new one, causing one extra unintended deletion.
                 if (UltraEdit.activeDocument.isFound()) {
                      UltraEdit.activeDocument.cutAppend();
                      i++;
            if (i == 0) {
                 UltraEdit.messageBox("No occurrences of \"" + delString + "\" found in this file.\r\n No lines were deleted.");
            } else {
                 // Create a new file for the report
                 UltraEdit.newFile();
                 UltraEdit.activeDocument.write(i + " lines containing \"" + delString + "\" were found and deleted in this file.\r\n\r\n");
            6,614548
              May 24, 2010#6
              I don't have UEX and therefore can't give you a verified answer. What happens when you change the while loop to following?
              while (1) {
                        i++;
                   else break;
              If the error is now on line 24, the command isFound() is not available in UEX. As workaround following script could be used which is surely much faster than your version.
              i = 0;
              while( UltraEdit.activeDocument.findReplace.find(delString) ) {
                   i++;
              if (i == 0) {
              } else {
              Above script tested with UltraEdit for Windows.
