Problem searching project files (fixed)
    May 17, 2016#1
    I have just installed UltraEdit 15.1.0.8 on Ubuntu 10.04 64 bit.
    I have created a project and I try to search text using the method "Project Files".
    I doesn't work with the 2 methods of project : Group Folder and Folder.
    It works searching directly inside a folder.
    Someone have a solution?
    Thanks in advance
    Vincent
      May 18, 2016#2
      What happens if
      1. a project is opened,
      2. Project Files selected in Find in Files,
      3. string to find is an empty string, i.e. no string to find.
      This Find in Files should result in listing all project files according to project settings at least on Windows. I'm not using UEX, just UltraEdit for Windows.
        May 18, 2016#3
        If I have the 3 conditions, nothing happens.
        If I search a term that I'm sure to find in files, nothing happens.
        If I search the same term in files in a folder, it works.
        Vincent
          May 18, 2016#4
          Do you see on tab Project of File View the project files listed at all?
          I viewed the UEX power tip about Projects and according to the screenshots on this page you should see the project files listed on this tab in UEX.
            May 18, 2016#5
            Thanks for your reply
            Yes, all the files are in my project : see the picture (sorry, it's in French) :
            Project files
            The search engine using the project files doesn't work with the generic Linux version, I think.
            Vincent
              May 18, 2016#6
              Okay, so the source of the problem must be searched definitely in Find in Files not working for Project Files on your system.
              I can't help further as I'm not using UEX and don't have Ubuntu 10.04 to be able to test that by myself.
              I suggest to contact IDM support by email regarding this issue if nobody else replies here with more information in the next days and depending on urgency for a fix of this issue. It looks like IDM support should be notified by you by email in any case to get knowledge about this issue.
              Edit: The issue was fixed with 16.10.0.22 of UltraEdit for Linux according to IDM support after being reported by a different user discovering a similar issue.
                May 20, 2016#7
                Thanks for all your replies.
