How to let ruler start column counting with 0 instead of 1?
    Nov 06, 2015#1
    I am fairly new to UltraEdit so forgive my inexperience. Is there a way to have the Column Ruler begin at position 1 instead of 0?
    6,616548
      Nov 07, 2015#2
      Open Advanced - Configuration - Editor Display - Miscellaneous and uncheck setting Start ruler numbering at column 1.
      This setting could be also found by opening Advanced - Configuration, typing in Find edit field the word ruler and hitting key RETURN or ENTER or clicking on button Go to jump to the setting.
      By the way: This setting is only for column ruler at top. The column number in status bar starts always with 1 for first column.
        Nov 09, 2015#3
        Thanks. This is exactly what I needed.
