Set line spacing on toolbar?
15
    Mar 25, 2008#1
    I occasionally want to shift between single, 1 1/2, and double spacing. I know I can do that by going into the View menu and choosing "Spacing," but I'd prefer to have this possibility available on my toolbar. To my surprise, when I went to add this to my customized toolbar, I couldn't find a command to add. Did I simply miss it, or is it not possible to add this to the toolbar? (I should perhaps add that I'm using UltraEdit 14 on Windows XP Pro.)
      Mar 26, 2008#2
      These commands are really not available for the toolbar. You could open the *.tb1 file you currently use in UltraEdit and add the commands:
      ID_VIEWSPACING_NORMAL
      ID_VIEWSPACING_ONEHALF
      ID_VIEWSPACING_DOUBLE
      save the file, close UltraEdit and restart it. But you will not be very happy because these 3 commands have no icon as you can see in the menu. You have to create 3 bitmap files with the correct dimensions and with top left pixel color as transparent color for the 3 commands. Then you could add the 3 commands with the 3 bitmaps as follows into your toolbar profile file:
      tabB ID_VIEWSPACING_NORMAL Full file name without double quotes to bitmap 1
      tabB ID_VIEWSPACING_ONEHALF Full file name without double quotes to bitmap 2
      tabB ID_VIEWSPACING_DOUBLE Full file name without double quotes to bitmap 3
      That should work. But never open the customization dialog for this toolbar later in UltraEdit. It will automatically remove these 3 commands.
      Best solution would be to contact IDM support per email and ask for adding these 3 commands with icons to the toolbar customization dialog in a future version.
      15
        Mar 26, 2008#3
        Thanks very much, Mofi. I think your last suggestion sounds like my best bet.
          Aug 29, 2011#4
          Great answer Mofi.....
          It works for me.
