Replace in read-only files
    Jan 21, 2007#1
    This might belong in a different forum but...
    I have a read-only file, and I want to do some replaces in it before I decide whether or not to save it (as a new file).
    The "Replace" tool is not available to me when the file is read-only. Is there a way to override this? It seems silly to me that it is unavailable - UE should let me do the replace, and then when I go to quit, it should prompt me to save this new file (or discard it).
    Any help appreciated.
    Tom S.
    206
      Jan 21, 2007#2
      Can't you just do a Save As before trying the search and replace?
      Software For Metalworking
        Jan 22, 2007#3
        mrainey56 wrote:Can't you just do a Save As before trying the search and replace?
        Yes, I could do a 'save as', but that's what I'm trying to eliminate. Basically I get a read-only file, I want to do the replace, look at it, copy some of it to the clipboard and then throw it away. If I did a save as, then I'd have to clean up (delete) that new file.
        Tom
        6,616548
          Jan 22, 2007#4
          To delete a file from within UltraEdit you can use File - Special Functions - Delete Active File. I use Alt+Del to do that.
          You can also copy the whole content of the file to a new file before editing: Ctrl+A, Ctrl+C, Ctrl+N, Ctrl+V.
          I personally think, UltraEdit does it right. If a file is read-only, you cannot do any action which modifies the content. I really, really don't like the MS Office method to allow editing a read-only file and then when I want to save it, it is not possible because the file has set the read-only attribute which I have forgotten to remove before starting editing.
          UltraEdit lets you set a file as read-only even if the file has not the file attribute read-only set - see Edit - Read Only. There is a special configuration setting for read-only file handling too - see Advanced - Configuration - File Handling - Miscellaneous - Change file read-only attribute when changing menu setting.
            Jan 30, 2007#5
            I think it would be a good thing to be able to set in the options/settings. Do you want to be able to edit read-only files (and then have to save with a different name of course)?
            That would make everyone happy- the people who want to and the people who don't.
            Tom
