Line Comment for AS400/RPG
    Dec 07, 2009#1
    I want to define a regular expression for Line Comment.
    It should be :
    1. If position 7 is a '*' character, then comment all the line;
    2. Whatever shows from position 81, comment all from position 81 to the line end.
    Now I just can make 1. work via:
    Line Comment = * Line Comment Valid Columns = [7]
    But I have no ideas for 2. Is there any kindly to help this? Thanks a lot.
    6,616548
      Dec 07, 2009#2
      The second rule is not really possible because regular expressions are not possible yet (= UE v15.20.0.1022) except for function strings. And for line comments there must be a comment starting string.
      I can only suggest following:
      Line Comment Num = 1  Line Comment Valid Columns = [80] Line Comment Alt = * Line Comment Valid Columns Alt = [7]
      Please note: There are 2 spaces after Line Comment Num = 1.
      With this definition everything after column 80 is highlighted as comment when in column 80 there is a space character. To be 100% correct the space at column 80 is also highlighted as comment which of course you can see only when using a different background color for comments.
      You can also use
      Line Comment Num = 1  Line Comment Valid Columns = [80-4095] Line Comment Alt = * Line Comment Valid Columns Alt = [7]
      to start line comment highlighting with first space found after column 79.
        Dec 08, 2009#3
        Thank you. It's totally clear now.
