Unindent with [shift] + [tab] does not work as expected on nothing selected
32
PostNov 10, 2018#1
I would like to un-indent a line by pressing [shift] + [tab]. Pressing the key combination in UE leads to inconsistent behavior. I.e. sometimes the caret is placed two spaces (or a tab) back on the line. Other times nothing happens at all.
I have looked in my settings to see if there is anything I have configured that would explain this.
Does anyone know if this is a bug?
PS: When I select multiple lines [shift] + [tab] works a expected.
Thanks in advance for your reply,
Mike
6,823625
PostNov 10, 2018#2
Shift+Tab works as designed as far as I could see using UE v25.20.0.88 (Windows 7) and v22.20.0.49 (Windows XP).
Shift+Tab moves caret to previous tab stop position in line on nothing selected or there is just a selection within a line. On usage of multi-caret feature all carets are moved to previous tab stop position in the lines on which carets are blinking in file.
Shift+Tab un-indents all selected lines to previous tab stop position on one or more lines selected. A selection can start somewhere in the middle of a line and can end also somewhere in the middle of a line. This works also with multiple selections on using multi-caret/multi-selection feature. But at least one line ending must be within a selection for triggering the un-indent instead of caret moving behavior.
Please take into account on using word-wrap on active file with wrap at window edge or wrap after column # that a selection can span over multiple displayed lines, but the selection does not include a line termination, i.e. carriage return + line-feed (DOS/Windows), just line-feed (UNIX), just carriage return (MAC prior OS X). The selection spanning on display over multiple lines is in real just within a line in file in this case.
Please have also a look on:
32
PostNov 10, 2018#3
Mofi, thanks for your quick response, so the shift tab functions as intended.
Looks like I will have to write (or find) a macro or script to un-indent my line.
Thanks anyway.🙂
6,823625
PostNov 10, 2018#4
There is the command Select line which has by default no hotkey assigned. I suggest to open Advanced - Settings or Configuration - Key mapping and assign a hotkey to command Select line to quickly select active line independent on where the caret is positioned in active line. Next Shift+Tab can be pressed to un-indent this line.
