grouping order number and make new files
7
    Mar 20, 2005#1
    I have a long list file. and I have to select and copy the text by grouping order number and make 365 files.
    I have so many files deal with like belows
    please help me!
    many thanks.
    order1 aaaa ---> copy from this
    order1 bbbb
    order1 ccccc ----> to and make file1
    order2 dddd-----> copy from this
    order2 eeee---> to and make file2
    order3 fffff-----> copy from this
    order3 gggg
    order3 hhhh
    order3 iiiiiii----> to and make file3
    order4 jjjjj------> copying and make file4
    order5 kkk-----> copy from this
    order5 llllllll----> to and make file5
    order364
    order365 yyyy----> copy from this
    order365 cccc------> to and make file365
    261
      Mar 21, 2005#2
      I played around with something:
      UnixReOn
      SelectWord
      Key HOME
      Bottom
      Find Up "^c"
      Key HOME
      Key DOWN ARROW
      Cut
      NewFile
      SelectWord
      Find "order"
      Replace "File"
      SelectWord
      Cut
      Delete
      SaveAs "^c"
      CloseFile
      Basically, this uses the first word on the line to select and cut all of the lines that start with that word. It then saves the cut text to a file.
      (Note that the "^c" in find and saveas use the contents of the clipboard as the string.)
      You would want to save a copy of the original file since the macro cuts the text as it saves it.
      You may want to tweak the names a little if I made a bad assumption.
      Hope this helps!
      Dave
      ASTTMan
      I'm not a Texan, I just live here.
      7
        Mar 23, 2005#3
        Thank to your answer !
        I adjust your tip to my works. and it works.
        thank you again.
