Look in another file and apply a change in the current
    Mar 24, 2005#1
    I am going through my current file and for each word I am looking in another file to see if that word is in there, if it is I want to be able to change my current word to something different. I have it set up to the point where I can look in the other file, but I have no way of returning wether it found something or not. If there anyway to get a return type from FindInFiles or be able to search the output window or anything like that?
    Here's an example of my code:
    UnixReOn
    IfEof
    SelectWord
    FindInFiles MatchWord OutputWin "Dir" "File" "^c"
    ** I need that function to return true or false **
    ToUpper
    Key RIGHT ARROW
    Key RIGHT ARROW
      Mar 24, 2005#2
      Open also the other file before running the macro.
      Replace
      ToUpper
      with
      NextWindow
      Find MatchWord "^c"
      PreviousWindow
      ToUpper
      PreviousWindow
      in your macro.
        Mar 24, 2005#3
        Thanks a million... That worked perfectly!
