Select text between quotes
    Jul 21, 2011#1
    Could you please help with a macro which selects text between quotes ("|') (excluding quotes)?
    I've written a macro which selects text, but it includes the quotes.
    Thx
      Jul 21, 2011#2
      A very quickly created version.
      Find RegExp "["']"
      Find RegExp "[~"']+"
      That macro does not take escaped quotes into account. And the caret should never be set inside a string on execution.
      The Perl regular expression experts perhaps find better solutions than this simple approach with UltraEdit regular expression engine.
      BTW: If you need that macro only for selecting quickly a string, try double clicking with primary (left) mouse button while Ctrl key is pressed.
        Jul 21, 2011#3
        Works like a charm!
        Thank you very much.
        Mofi wrote:And the caret should never be set inside a string on execution.
        Modified your macro to select text if caret is inside a string.
        UltraEditReOn
        Find RegExp Up "["']"
