Find Selected text not ok
5
    Apr 15, 2005#1
    says, i have those line below and i want to keep the first line only, but want to delete those 0504 in the rest of file
    8759 6981 0504 <- always at first line for searching and wanted.
    8112 6981 0504 <- 0504 to be deleted
    7771 6451 0504 <- 0504 to be deleted
    6661 6166 0504 <- 0504 to be deleted
    i want the result as below:
    8112 6981
    7771 6451
    6661 6166
    here my macro that failed, it doesnt keep the line 8759 6981 0504 , instead it delete whole 0504 in the file.
    copy // 0504
    Find RegExp "^c"
    Replace All ""
    is it possible to use selected line and then replace it?
    206
      Apr 15, 2005#2
      Try this:
      UnixReOn
      Key HOME
      Find RegExp "^([0-9].*)0504$"
      Replace All "\1"
      Find "@~@"
      Replace ""
      Software For Metalworking
      5
        Apr 16, 2005#3
        Foremost, thanks. The result from 1) to (2)
        (1)
        8759 6981 0504
        8112 6981 0504
        7771 6451 0504
        6661 6166 0504
        (2)
        8759 6981
        8112 6981 0504
        7771 6451 0504
        6661 6166 0504
        but i would like the answer below
        8759 6981 0504
        8112 6981
        7771 6451
        6661 6166
        206
          Apr 16, 2005#4
          When I put the cursor anywhere in the first line containing a string of digits,(8759 6981 0504 in this case), then run the macro, it works properly for me.
          This slight modification will find the first line ending in 0504 for you before making the changes.
          Otherwise, I guess I'm not sure what you're after.
          UnixReOn
          Find RegExp "0504$"
          Key HOME
          Replace All "\1"
          Find "@~@"
          Replace ""
          5
            Apr 17, 2005#5
            Again, thanx.
            The above solution done well.
            Now, let say i have the line below
            8759 6981 0504 (but if the 0504 is changing to any random number, eg 9777, 6623, 8511. That means the third number is always need to be changed.)
            7673 7136 0775 7393
            4550 0664 6985 1391
            0504 0207 5946
            my solution here not working
            UnixReOn
            top
            key end
            key left arrow
            SelectWord
            Find RegExp "^s[\t]"
            Key HOME
            Find RegExp "^([0-9].*)^s[\t]"
            Replace All "\1"
            Find "@~@"
            Replace ""
              Apr 17, 2005#6
              xmen wrote:Again, thanx.
              8759 6981 xxxx // xxxx is any random number and wish to be
              // selected and changed
              7673 7136 0775 7393
              4550 xxxx 6985 1391
              0504 0207 5946
              wanted result is
              8759 6981 xxxx
              7673 7136 0775 7393
              4550 6985 1391
              0504 0207 5946
              UnixReOn
              top
              key end
              key left arrow
              SelectWord
              Key HOME
              Replace All "\1"
              Find "@~@"
              Replace ""
                Apr 19, 2005#7
                since ^s not working, alternative solution is to use ^c, here the code
                GotoLine 1
                Loop 10
                Key RIGHT ARROW
                SelectWord
                Find "^c" // find the first line random number
                Key END
                Find "^c" // find the 2nd then replace, Similiar to "Find & replace" button
                Replace ""
