Macro formatting
Macro formatting
112
112
    May 20, 2005#1
    I notice that even if I format the macros (with tabs and indents) when I save the macro, everything is shifted left - which makes it difficult to trace loops and stuff for really complicated macros.
    Any solution to this?
    Cheerz,
    Paolo
      May 20, 2005#2
      I'm afraid not!
      Stephen_Hatton
      Stephen_Hatton
        Jun 15, 2005#3
        Hi PaoloFCantoni
        I put the "Top" command between each section, and if you read another post regarding comments in macros, that might help you also.
        Regards
        Ing. Stephen Hatton
        :idea:
