How create a bak file only if search/replace has made change?
emmchild
    May 27, 2005#1
    The macro below performs a search/replace command on all open files, saving and closing each file as it goes.
    I have two questions concerning the "bak" files that are created automatically for each file the macro processes.
    1. Is there a macro command to prevent the bak files from being created entirely?
    2. Is there a way to have a bak file created ONLY in the event that changes are actually made to the file? That is, if after the search/replace, the file has not been changed, don't save it, or save it but don't create a bak file.
    UnixReOn
    IfNameIs ""
    Find RegExp "([^,\n])"([^,\n])"
    Replace All "\1(qt)\2"
    CloseFile Save
      May 27, 2005#2
      This is untested. You can turn off .bak creation entirely in the UE Configuration.
      UnixReOn
      IfNameIs ""
      CloseFile Save
      CloseFile NoSave
      Software For Metalworking
      emmchild
      emmchild
        May 28, 2005#3
        That'll do it. Thanks!
        emmchild
        emmchild
          May 28, 2005#4
          Actually, I have several find/replace expressions. I'd like to save the file if one or more of the finds have succeeded.
          Can't see how to do it with IsFound (and without the ability to create and test variables in a macro). Any further suggestions?
          Find RegExp "([\s][,])"|([,][\s])""
          Replace All "\1(qt)"
          206
            May 28, 2005#5
            I haven't tried this before.
            A macro to do this:
            Create a blank line at the top of your file
            Do the first search/replace
            If the search string is found, replace  then go to the top of the file and put a @ (or some other character) in the blank line - this becomes your flag
            If not found, do the next search/replace just like the first, add a @ if found
            Do as many search/replace sequences as you need, all with a @ added to the top line if the search string is found
            After they're all done, go to the top and see if the first character is @ - which it will be if even one search string was found
            If yes, delete the line, close with save
            If no, close with no save.
            I may be overlooking something, let me know how it works out.
            emmchild
            emmchild
              Jun 02, 2005#6
              mrainey56 wrote:If the search string is found, replace  then go to the top of the file and put a @ (or some other character) in the blank line - this becomes your flag.
              Great idea! I set out to implement it and ran into this strange error, which I can't figure out.
              This segment of macro code causes a "Incorrect macro command in macro line" error on attempt to close the macro editor. Paste it into your editor and you'll see.
                Jun 02, 2005#7
                emmchild
                emmchild
                  Jun 02, 2005#8
                  Thanks Mofi and thanks mrainey56. Your idea worked fine.
                  UnixReOn
                  IfNameIs ""
                  IfCharIs "@"
                  DeleteLine
                  CloseFile Save
                  CloseFile NoSave
