End sort i.e. sort by ending of a word
24
    Oct 07, 2013#1
    I am trying to sort a file in Urdu by the character by which it ends. Each word is on a separate line
    An example in English would help:
    lychee
    fruit
    banana
    apple
    pear
    cherry
    I need the sort to be on the last letter of the word and then sorted recursively in reverse order
    banana
    lychee [i]This comes before apple[/i]
    apple
    pear
    fruit
    cherry
    A macro or a script would do just great.
    Just in case someone wants to work with live data, here is a small sample:
    ببا
    ببجا
    ببچو
    ببد
    ببر
    ببڑ
    ببز
    ببستگيا
    ببلا
    ببلو
    ببلے
    ببلی
    ببند
    ببنسلکلگے
    ببنسلکلئ
    ببهنو
    ببہتر
    ببھا
    ببھر
    ببھی
    ببو
    ببيا
    ببيشتر
    ببے
    ببی
    بپا
    بپتا
    بپتسما
    بپد
    بپر
    بپفسر
    بپلی
    بپھر
    بپو
    بتا
    بتبا
    بتتر
    بتتے
    بتتی
    بتجد
    بتجو
    بتحقی
    بتخے
    بتد
    بتذ
    بتر
    بتز
    بتستا
    بتصحی
    بتصر
    بتطا
    بتعثنا
    Many thanks
    6,684587
      Oct 07, 2013#2
      Here is a macro solution which I have tested only on English example. It works hopefully also on Urdu words.
      PerlReOn
      Find MatchCase RegExp "^(.)"
      Replace All "\1#"
      Loop 0
      Find MatchCase RegExp "^(.+#)(.)"
      Replace All "\2\1"
      IfNotFound
      Find MatchCase "#"
      Replace All ""
      SortAsc IgnoreCase 1 -1 0 0 0 0 0 0
      Replace All "\1#"
      Loop 0
      Replace All "\2\1"
      IfNotFound
      Find MatchCase "#"
      Replace All ""
      The macro reverses first all characters within a line. So for example fruit becomes tiurf. Then the lines are sorted ascending. And finally the macro reverses all characters within a line again. # is used temporarily on reversing the characters. This character should be not present in the file or the macro produces wrong output.
      24
        Oct 08, 2013#3
        Many thanks. The macro worked like a charm.
