Need to save each line as a new file using part of the line
preichar
    Jun 21, 2005#1
    Need to save each line as a new file using part of the line as the name. See next:
    Here is my current file:
    first_name=&last_name=&city=&rowBegins=00001&reference=/memberdirectory/results.cfm
    first_name=&last_name=&city=&rowBegins=00026&reference=/memberdirectory/results.cfm
    first_name=&last_name=&city=&rowBegins=00051&reference=/memberdirectory/results.cfm
    first_name=&last_name=&city=&rowBegins=00076&reference=/memberdirectory/results.cfm
    first_name=&last_name=&city=&rowBegins=00101&reference=/memberdirectory/results.cfm
    I want to save the first line into a file all by itself and name it 00001.txt
    Then the next line should be in a file all by itself and named 0026.txt and so on, there are 1510 line in theis file, so I am looking for 1510 .txt files when I am done.
    All of my attempts at a macro have produced nothing short of a complete mess! :)
    Thanks for some help!
    Jason.
      Re: Need to save each line as a new file using part of the l
      Jun 22, 2005#2
      That's really tricky, but I found the solution. It cannot be done with a UE macro directly. But the file can be converted by a macro to macro code, which does the job. Here is the macro, which converts your file into macro code.
      Bottom
      IfColNum 1
      Find RegExp "%^(*Begins=^)^([0-9]+^)^(*^)$"
      Replace All "SelectAll^p"^1^2^3^p"^pSaveAs "^2.txt""
      "InsertMode
      NewFile
      When you run this macro on your file, you will get
      NewFile
      SelectAll
      "first_name=&last_name=&city=&rowBegins=00001&reference=/memberdirectory/results.cfm
      SaveAs "00001.txt"
      SelectAll
      "first_name=&last_name=&city=&rowBegins=00026&reference=/memberdirectory/results.cfm
      SaveAs "00026.txt"
      SelectAll
      "first_name=&last_name=&city=&rowBegins=00051&reference=/memberdirectory/results.cfm
      SaveAs "00051.txt"
      SelectAll
      "first_name=&last_name=&city=&rowBegins=00076&reference=/memberdirectory/results.cfm
      SaveAs "00076.txt"
      SelectAll
      "first_name=&last_name=&city=&rowBegins=00101&reference=/memberdirectory/results.cfm
      SaveAs "00101.txt"
      Now copy your converted file into the edit macro dialog and run the macro.
      261
        Jun 22, 2005#3
        Jasgot,
        I think you can do it this way as well:
        UnixReOn
        Bottom
        IfColNum 1
        IfEof
        SelectLine
        Key HOME
        NewFile
        Find RegExp "^(.*rowBegins=)(\d+)(.*)$"
        Replace "\1\2\3\n\2.txt"
        Key HOME
        Cut
        Key DEL
        SaveAs "^c"
        CloseFile NoSave
        This uses UNIX RE and assumes the new files go in the same directory as the current file.
        Dave
        ASTTMan
        I'm not a Texan, I just live here.
