Delete records that have duplicate text strings
    Jun 28, 2005#1
    UltraEdit/UltraCompare question.....
    I know how to sort the following text file using specific columns, however, I need your help in deleting entire records anytime matches are found when examining specified columns (columns 1-11 in example). For example, after some unknown procedure is complete, I would like to just have the one record (Kelly Smith) left.
    -----------sample file -------------
    Eddie Smith
    Eddie Smith likes soda
    Kelly Smith likes crackers
    Mikie Smith
    Mikie Smith likes food
    Steve Smith
    Steve Smith likes cola
      Sep 24, 2005#2
      Maybe 3 months too late, but I think, I have now understand what you want. Here is a macro which does the job. But there is one restriction for this solution: The first 11 characters of all lines must have non of the characters, which are special characters for a regular expression in UltraEdit style. This condition is true for your example.
      Bottom
      IfColNum 1
      Find RegExp "%???????????"
      IfNotFound
      Key HOME
      ToggleBookmark
      Key DOWN ARROW
      Find RegExp "%^c"
      GotoBookMark
      ToggleBookmark
      Find RegExp "%^c*^p"
      Replace All ""
      GotoBookMark
      ToggleBookmark
      Key DOWN ARROW
      UnixReOn
      Remove the last red command, if you use regular expression in UltraEdit style by default instead of Unix style - see Advanced - Configuration - Find - Unix style Regular Expressions. UnixReOn/UnixReOff modifies this setting.
