Renumbering only lines with text ignoring blank lines
    Jun 04, 2015#1
    I want to renumber only the lines with text and not 8) number blank lines. Is there any hope for me? I search for lines with the letter N and numbers followed by spaces and delete them until I get to the end of the file. Then renumber the entire file.
    ColumnModeOn
    UltraEditReOn
    Loop 0
    Find RegExp "[N][0-9]+[ ]+"
    IfNotFound
    Delete
    ColumnInsert " "
    ColumnInsert "N"
    Key RIGHT ARROW
    ColumnInsertNum 1000 10
      Jun 04, 2015#2
      For small files I would do this with a script which loads entire file into memory, modifies there the beginning of the lines and outputs all lines at once overwriting entire file content. This would have the advantage of producing only one undo record.
      However, here is a macro solution for this task in style required to copy the code into Edit Macro dialog with property Continue if search string not found being enabled for this macro. The macro is written for files with DOS/Windows line terminators. Replace all ^p by ^n in macro for UNIX files not converted to DOS on load.
      First number and increment can be of course modified in macro code, too.
      TrimTrailingSpaces
      IfCharIs 13
      Find MatchCase RegExp "[^r^n]+"
      Cut
      IfCharIs 10
      Cut
      Bottom
      Loop 0
      IfColNum 1
      Key BACKSPACE
      Delete
      Find MatchCase RegExp "%N[0-9]+ +"
      Replace All ""
      Loop 0
      Find MatchCase RegExp "^p$"
      Replace All "^pBlAnKlInE"
      IfNotFound
      Find MatchCase "^pBlAnKlInE"
      Replace All "BlAnKlInE"
      ColumnModeOn
      ColumnInsert "N "
      Key RIGHT ARROW
      ColumnInsertNum 1 1
      Bottom
      InsertLine
      Find MatchCase RegExp "N^( +^)^([0-9]+^)"
      Replace All "N^2^1"
      Find MatchCase "BlAnKlInE"
      Replace All "^p"
      Here is the same code again, but with indentations and comments for better understanding the code:
      //  Delete all trailing spaces/tabs from all lines to convert all blank lines
      //  to empty lines. For details see the post "Remove / delete blank and empty
      //  lines" at https://forums.ultraedit.com/viewtopic.php?f=8&t=13703#p48039
          TrimTrailingSpaces
      //  Cut all blank lines at beginning of file to user clipboard 9 if there are blank lines.
          IfCharIs 13
              Cut
          IfCharIs 10
              Cut
      //  Insert at top a character to make sure the loop below does not result
      //  in an endless running loop if this macro is executed on an empty file.
      //  Delete all line terminators at end of file.
          Bottom
          Loop 0
              IfColNum 1
                  Key BACKSPACE
      //  Delete the inserted character at top of file.
          Delete
      //  Delete all already existing line numbers at beginning of all
      //  lines after character N and also all spaces after each number.
          Replace All ""
      //  Insert the uncommon written and therefore most likely never existing
      //  string BlAnKlInE on every blank line. This must be done in a loop as
      //  there can be multiple blank lines in series.
          Loop 0
              IfNotFound
      //  Remove the line terminator before every previously blank line.
      //  Insert at beginning of each line character N and a single space.
          ColumnModeOn
          ColumnInsert "N "
      //  Insert after character N the incrementing decimal number
      //  starting with value 1 and incrementing on each line by 1.
          Key RIGHT ARROW
          ColumnInsertNum 1 1
      //  Move to end of file and insert a line termination.
          Bottom
          InsertLine
      //  Back at top of file move all spaces left to inserted number right
      //  to the number in case of left alignment is wanted for the numbers.
          Replace All "N^2^1"
      //  Restore the blank lines with a simple replace.
          Replace All "^p"
      //  Restore the blank lines at top of the file.
