Cursor to Beginning of Line
8
    Jul 07, 2005#1
    This is probably a really easy one.
    I have found all the Key commands except I want a command that will put my cursor to the very beginning of the line that I am in not matter if the line contains tabs or spaces.
    Please advise. Thanks
    206
      Jul 07, 2005#2
      The Home key.
      Software For Metalworking
        Jul 08, 2005#3
        The Home key does it, when at Advanced - Configuration - Edit the option Home Key Always Goto Column 1 is set.
        46
          Jul 11, 2005#4
          If you don't want to set the option, you can simply use this macro:
          Key HOME
          IfColNumGt 1
          Key HOME
          This will ever move the cursor at beginning of a line.
          Never forget: "Above the clouds, The sky is blue and the sun shine"
