Macro to run selected SQL code and display results
    Jul 08, 2005#1
    Copy the selected sql code into a file, perhaps use isql (or oracle equivalent) to run the sql, piping the output into a file that is then loaded by UE
    Anyone got anything that does something like that?
      Jul 08, 2005#2
      OK, no one came up with a solution, so here's mine (just invented)
      Its a bit dirty, and involes a macro and setting up a tool
      Macro:
      UnixReOn
      IfSel
      NewFile
      SaveAs "C:\temp\sql.tmp"
      CloseFile NoSave
      RunTool "XXRun SQL"
      Tool setup:
      cmd line: "C:\Program Files\Microsoft SQL Server\80\Tools\Binn\isql.exe" -U sa -P yourpwd -d Northwind -i "c:\temp\sql.tmp" -w 1000 -e -n -r
      tool settings: Create New file, Capture Output
      I havent figured out a good way to specify the database name - shame its not possible to ask for params somehow?
