CloseFile NoSave macro for multiple files
5
    Jul 22, 2005#1
    Hello
    Im looking for a macro that can close all open documents with CloseFile NoSave.
    I tried to create a macro, but I can't seem to get the looping right.
    It always hangs on the last document.
    Larre
      Re: CloseFile NoSave macro for muliple files
      Jul 22, 2005#2
      That macro does it, but only for named files. New "files" which are not saved at least once will not be closed.
      IfNameIs ""
      CloseFile NoSave
      5
        Jul 22, 2005#3
        Thanks Mofi
        It's those new "files" which are not saved at least once that I need this macro for. I normally do my more complicated oracle stored procedures in several steps, and I tend to have one not saved file for each step.
        So if you have a solution for not saved files you would make my day.
          Jul 24, 2005#4
          OK. Here is the macro which closes all opend files, independent of save state.
          IfColNum 1
          CloseFile NoSave
