IfFound condition is unexpected true on no replace done on selected text because of no selection
6
    Sep 22, 2019#1
    Please test this tiny macro on several files (including empty ones) without any text selected.
    The macro DOES NOT CHANGE THE FILE.
    If no text is selected, the GetString should never be executed.
    But it sometimes does and I cannot figure out why/when.
    PerlReOn
    Find RegExp SelectText "xsftq"
    Replace All "`"
    GetString "ERROR"
    I'm using UltraEdit Text/Hex Editor (x64) Version 26.20.0.6.
      Sep 23, 2019#2
      Congratulation! You found a curious bug. I can reproduce this issue with UE for Windows from version 22.00.0.46 to version 26.20.0.6, but not with versions before 20.00. It looks like an undefined behavior caused by a not initialized variable on no Perl regular expression replace executed on selected text because of nothing selected in the active file. I reported this issue by email to IDM support.
      Workaround 1: Do not use a Perl regular expression by removing RegExp.
      PerlReOn
      Find SelectText "xsftq"
      Replace All "`"
      GetString "ERROR"
      Workaround 2: Use UltraEdit or Unix regular expression engine by replacing PerlReOn by UltraEditReOn or UnixReOn.
      UltraEditReOn
      Replace All "`"
      GetString "ERROR"
      Workaround 3: Run the Perl regular expression replace on selected text only if there is a selection by using IfSel with a matching EndIf.
      IfSel
      PerlReOn
      Replace All "`"
      GetString "ERROR"
      jimvj
      6
        Sep 23, 2019#3
        Thanks Mofi. I thought I was seeing things.
