Cleaning Filtered HTML from Microsoft Word documents to be used to paste into content areas of Web Site CMS systems
5
    May 20, 2021#1
    Hello!
    Well, after working on posting content to online CMS systems, from clients sending me a Microsoft Word file, I have come up with this:
    First, save the file out in Microsoft Word as a Filtered HTML for CMS systems.
    It generates a fair HTML output, but there is still a lot of in-line formatting and other stuff that needs to be edited out.
    I wrote this macro to help.
    It still requires manual work to set up ordered and unordered lists, but a lot better than doing all the formatting deletion.
    I have attached sample files from the original Word file, and the cleaned up result of the macro.
    Here is the macro:
    UltraEditReOn
    Find "<html>"
    Key DEL
    UltraEditReOn
    Find "<head>"
    UltraEditReOn
    Find Select "</head>"
    Key DEL
    UltraEditReOn
    Find "<body"
    UltraEditReOn
    Find Select ">"
    Key DEL
    Loop 0
    UltraEditReOn
    Find "class="
    Find Select ">"
    Key LEFT ARROW
    Key DEL
    UltraEditReOn
    Find "style="
    Find Select ">"
    Key LEFT ARROW
    Key DEL
    UltraEditReOn
    Find "</body>"
    Key DEL
    UltraEditReOn
    Find "</html>"
    Key DEL
    Loop 0
    Find "<span"
    Find Select ">"
    Key DEL
    "<span>"
    Loop 0
    Find "<p "
    Find Select ">"
    Key DEL
    "<p>"
    PerlReOn
    Find MatchCase RegExp "^(?:[\t ]*(?:\r?\n|\r))+"
    Replace All ""
    UltraEditReOn
    Find "<p>"
    Key DEL
    "<h3>"
    Find "</p>"
    Key DEL
    "</h3>"
    There may be shorter ways using complex pattern matching, but probably anyone can understand this one.
    If anyone has any suggestions, please let me know.
    Mark
    Marketing_Newsletter.doc (48 KiB)   1
    Microsoft Word document to save as filtered HTML file with MS Word
    Cleaned_up_Fixed_Marketing_Newsletter.htm (13.93 KiB)   1
    Results HTML file after macro execution to clean up the HTML file created by Microsoft Word
    6,688586
      May 24, 2021#2
      I suggest the following macro for this task using mainly Perl regular expression replaces because it is easier with the Perl regular expression engine to handle multiple variants with one expression than on using legacy UltraEdit regular expression engine.
      UltraEditReOn
      Find MatchCase RegExp Select "<body[~>]++>[^t ]++^p"
      IfSel
      Delete
      ExitMacro
      TrimTrailingSpaces
      PerlReOn
      Find MatchCase RegExp "(?:\r\n)?<div class=WordSection1>(?:\r\n)*"
      Replace All "<div>"
      Find MatchCase RegExp "(?:\r\n)?</div>(?:\r\n)+</body>(?:\r\n)+</html>(?:\r\n)+"
      Replace All "</div>"
      Find MatchCase RegExp "<span[^>]*?>|</span>"
      Replace All ""
      Find MatchCase RegExp "[\t ]+(?=<br>)"
      Replace All ""
      Find MatchCase RegExp "(?:\r\n)?<p[^>]*?>(?:<b>)?&nbsp;(?:</b>)?</p>"
      Replace All "<br>"
      Find MatchCase RegExp "<p[^>]*?>(?:<b>)?([\s\S]+?)(?:</b>)?</p>"
      Replace "\r\n<h3>\1</h3>"
      Find MatchCase RegExp "(?:\r\n)?<p[^>]*?>"
      Replace All ""
      Find MatchCase "</p>"
      Replace All "<br>"
      Find MatchCase RegExp "(?:<br>\r\n)+(?=</div>)"
      Replace "\r\n"
      Find MatchCase RegExp "(?:<br>\r\n)+[\t ]*\x95[\t ]*"
      Replace All "</li>\r\n<li>"
      Loop 0
      Find MatchCase "</li>^p<li>"
      Replace "^p^p<ul>^p<li>"
      Find MatchCase RegExp "(?:<br>\r\n){2,}"
      Replace "</li>\r\n</ul>\r\n\r\n"
      Find MatchCase RegExp "\x96"
      Replace All "&endash;"
      Find MatchCase RegExp "\x97"
      Replace All "&emdash;"
      Find MatchCase RegExp "\xA0"
      Replace All "&nbsp;"
      I tested this macro with UE v28.10.0.26 (currently latest version) as well as with UE v22.20.0.49 (latest version for Windows XP).
      I think, it produces a better result than your macro.
      Please let me know if the macro has to handle more variants than those found by me on analyzing the HTML file created from the Microsoft Word document file attached to your post using MS Word 2010.
      Please let me also know if I should explain some regular expressions or some macro code sequences or even the entire code and all expressions
