How to sort a txt file and output to new file
    Sep 07, 2005#1
    I am trying to input a 40 million row text file, sort it and output to a new file. I have successfully written a macro to sort a file and save it to itself. I am using a bat file to run. Below is the code I have but I don't know how to get it to save to new file in order to preserve the original in case something happens.
    SortAsc 47 78 235 242 1 42 43 46
    SaveAs "D:\HNDATA\CRMSdata\iservice50"
      Sep 07, 2005#2
      If you run the macro with a bat file, why do you not simply copy your file first with command copy your_original.txt copy_of_original.txt inside the batch file and then run the UltraEdit macro on the copy.
        Sep 07, 2005#3
        Is there any limitations as far as ultraedit is concerned as to how many records can be sorted?
          Sep 08, 2005#4
          According to help of UltraEdit, there is no special limit for sort. But for your extremly big file it will take a very long time. Best run the sort at night.
