How to remove line numbers and space from the beginning of all lines of a file?
    Feb 17, 2022#1
    I'm trying to create a script or macro to search each line as far as the first space character, select all text before and including the space and delete it. Here's some sample text, I want to remove all the numerical values from the beginning of each line. You can see there is a line between lines 9 and 10 staring with a Q which should not be affected. The format of the file is always the line number, space, then the content of the line.
    1 BEGIN PGM Model_0 MM
    2 ; 07.01.2022   14:53
    3 BLK FORM 0.1 Z X-75 Y-25 Z199.75
    4 BLK FORM 0.2 X75 Y25 Z250.5
    5 ; --- files_x\StartEnd\pgm_bgn.txt ---
    6 FN 17: SYSWRITE ID 507 NR0 IDX1.0 =+0
    7 FN 17: SYSWRITE ID 507 NR0 IDX2.0 =+0
    8 FN 17: SYSWRITE ID 507 NR0 IDX3.0 =+0
    9 CYCL DEF 247 PRESETTING ~
     Q339=+0    ;PRESET NUMBER
    10 ; -------------------------------------
    11 ;
    12 ; --- files_x\StartEnd\pgm_bgn_2.txt ---
    96 L X-81.327 Y-23.735 Z240.103
    97 L X-81.676 Y-23.713 Z240.134
    98 L X-81.868 Y-23.746 Z240.151 F50000
    99 L X-82.042 Y-23.835 Z240.168
    100 L X-82.182 Y-23.972 Z240.185
    101 L X-82.276 Y-24.143 Z240.202
    102 L X-82.314 Y-24.335 Z240.219
    103 L X-82.294 Y-24.529 Z240.237
    104 L X-82.217 Y-24.709 Z240.25
    I was working with this but it keeps searching every line for every space character, I couldn't get it to stop after the first one.
    ColumnModeOn
    UltraEditReOn
    Find " "
    DeleteToStartofLine
    MoveLineDown
    6,684586
      Feb 18, 2022#2
      The macro code for removal of line numbers at beginning of all lines using an UltraEdit regular expression replace all is:
      UltraEditReOn
      Find MatchCase RegExp "%[0-9]+ +"
      Replace All ""
      The plus after the space character can be removed to delete just the first space together with the line number.
