How to choose and play macro stored in a loaded macro file with multiple macros in UltraEdit for Linux?
15
    Jul 26, 2022#1
    I am using UE 20.00.0.34 for Linux. The menu doesn't show Advanced but instead Tools:
    File Edit Search Project View Format Column Tools Help
    Under Tools I find Macro. When I open this, I can see:
    Load ...
    Load and Append to Existing ...
    Save All ...
    Quick Record
    Set Auto Load ...
    Set Macro for File Load/Save ...
    Edit Macro ...
    Unload All
    Delete Macro/Modify Properties ...
    Record ...
    Stop Recording
    Play Again
    Play Any/Multiple Times ...
    O Show Post Macro Record Options
    O Warn on Exit if Macro Not Saved
    If I choose Edit Macro..., I can select macros I created in the past. However, here I can only choose Close, New Macro, or Modify.
    My problem: Nowhere can I find a way to play/run one of the macros I created in the past. How do I choose a specific macro to run?
      Jul 26, 2022#2
      Use Play Any/Multiple Times... or if UltraEdit for Linux supports also the Macro List view like UltraEdit for Windows used by me, there can be also opened this view listing all macros stored in currently loaded macro file and double clicked on one of these macros to run it on active file.
      DEnzmann
      15
        Jul 26, 2022#3
        I did not consider "Play Any/Multiple Times ..." because I only wanted to play one specific macro once, now I see. To denote this "Play Macro ..." would have been better. Thanks for your assistance!
